Fuel in oil - where to start? - Page 3 - SailNet Community
 3Likes
post #21 of 43 Old 07-03-2013
Re: Fuel in oil - where to start?
If the oil level is over the full mark or higher than when you last changed the oil, it is likely that the fuel is seeping through the carb into the pan. Even with good compression readings the fuel would probably seep past the rings. As mentioned earlier if the air/fuel mix through the carb was that rich it probably wouldn't run at all or if it did there would be lots of black smoke. If, when you first start it you blow a lot of smoke which eventually cleans out, it is likely seepage. If it never cleans out then the air/fuel mix through the carb is likely. Both could be caused by a faulty float valve. Pictures?
Let us know what you find.
Paul T
dabnis is offline
post #22 of 43 Old 07-11-2013 Thread Starter
OK...carb is off and rebuild kit is ordered from Sweden (sheesh). There was quite a bit of varnish and the main gasket was ripped.
Now that I'm into it more, I don't have a good feeling about this. I changed the oil again and the new oil I just put in came out milky and smelled like fuel after 10 minutes of running. This is an updraft carb, so a gravity leak is out. I'm now concerned it's a water leak AND a fuel leak. Head gasket? Cracked manifold or block? PO's going to get a love letter for sure...
--Skagit out
_____________________________________________
1975 Irwin 28 - hasn't earned a new name yet, but at this point it might not be flattering.
Skagit is offline
post #23 of 43 Old 07-11-2013
If a gravity leak is out it must be an overly rich condition through the carb. Does it run rough and smoke? It will be interesting to see what the re-built carb does?
"Milky oil"? doesn't sound good. If you are lucky it is just a head gasket. There are fluorescent dyes you can put in the coolant that may help show where the leak(s) are coming from.
Paul T
dabnis is offline
post #24 of 43 Old 07-11-2013
Just A Member
Dick6969's Avatar
gas in the oil has to come from the needle seat does not have enough pressure from float, runs in manifold down by rings into oil... on a motorcycle that is.
Dick6969 is offline
post #25 of 43 Old 07-11-2013
No...new fuel line is direct...tank -> pump -> regulator -> carb.
Is the old mechanical pump still on the engine? If so, are there any fuel lines still attached to it?
Paul T
dabnis is offline
post #26 of 43 Old 07-11-2013 Thread Starter
Paul T
Hey Paul-
No, old pump has been removed and the hole was covered with a bracket for the new one.
--Skagit out
Skagit is offline
post #27 of 43 Old 07-11-2013
milky oil almost certainly is a water contamination.
water contamination + fuel contamination = pretty much certainly a head gasket issue.
If you pull out a pint of oil and let it stand overnight in a tall bottle, like an olive jar, the oil and water usually will settle out visibly, confirming that it is water.
Check out the old Landrover field repair manuals, they detail how to take a fresh antelope hide and use it as a field replacement for a blown head gasket. The same can be done with the hide of the PO's back.
hellosailor is offline
post #28 of 43 Old 07-11-2013 Thread Starter
I have some of the mystery goo in a jar to see what happens. So far it hasn't separated. I've got some water detection paste coming that should answer the question for good.
You may be on to something there...
--Skagit out
Skagit is offline
post #29 of 43 Old 07-11-2013
Thieving paste! As it used to be called, used on dipsticks to check fuel tanks. IIRC turns purple if there is water. You must have found that on the internet, most shops swear it can't possibly exist, and it certainly ain't sold at the local parts-r-us franchise.
post #30 of 43 Old 07-11-2013
Hey Paul-
Oh my, thought maybe I was on to something. "No gravity leak" As I see it the fuel has to come through the carb when it is running. As the crankcase runs under very minimal vacuum, if the PCV valve is working properly, the only other thing I can think of is the fuel puddling in the intake manifold somewhere and then running, by gravity, though the rings?
When it is running does it smoke as if the choke was left on?
Paul T
dabnis is offline
Solid Fuel Stove Fuel HardTAC Gear & Maintenance 24 06-17-2013 09:15 PM
City marina to build self-service fuel station after three years without fuel - Corpu NewsReader News Feeds 0 07-17-2011 12:40 AM
I don't even know where to start. MariaDelMar Introduce Yourself 6 11-05-2009 09:47 AM
Where should I start dryclean General Discussion (sailing related) 5 06-07-2009 03:38 PM
Where to start, what to buy. puntapete Boat Review and Purchase Forum 16 11-05-2006 07:49 PM
