Fuel in oil - where to start? - Page 4 - SailNet Community
 3Likes
post #31 of 43 Old 07-11-2013 Thread Starter
Re: Fuel in oil - where to start?
{run_routine:"premature_celebration"}
WOOHOO! Water detection paste shows NO WATER! It must just be a large amount of fuel. On with the carb rebuild, and see where we go from there. WE MAY BE IN THE WATER THIS SUMMER BOYS!
--Skagit out
_____________________________________________
1975 Irwin 28 - hasn't earned a new name yet, but at this point it might not be flattering.
Skagit is offline
post #32 of 43 Old 07-16-2013 Thread Starter
{end_routine:"premature_celebration"}
Crap...sent the oil in to a lab for analysis. Positive for water and antifreeze. Ah well, at least I understand possible sources of fuel contamination better.
--Skagit out
Skagit is offline
post #33 of 43 Old 07-16-2013
Paste says no, lab says yes...OTOH I'm glad that what I remembered (milky oil is water contamination) has been upheld. OTOH...sorry to hear that. I guess that also means the paste is good for gross contamination, i.e. separate layers of water, rather than water that is mixed in nicely.
hellosailor is offline
post #34 of 43 Old 07-16-2013
Mechsmith
If you are raw water cooled where did antifreeze come from? If not raw water cooled you should have some evidence in the heat exchanger. Either loss of coolant or muck in it.
Seafarer 29 KCB
Mechsmith is offline
post #35 of 43 Old 07-17-2013 Thread Starter
PO winterized with antifreeze...only so many places it can come from and all are expensive. Going to pull the engine in the next few weeks and see what we got.
--Skagit out
Skagit is offline
post #36 of 43 Old 07-17-2013 Thread Starter
Yeah, the paste just doesn't have the sensitivity to pick up small amounts of water in emulsion. Lab results came back as 5% water. That's after 10 min of running.
--Skagit out
Skagit is offline
post #37 of 43 Old 08-06-2013 Thread Starter
In case anyone's following this...here's the latest.
Took the head and exhaust manifold off, both look sound. I'm 99% sure I'm the victim of a poorly designed exhaust system. With the exception of about 6" of downhill exhaust pipe, the entire exhaust system is above the manifold discharge. With the static level of the water in the pipe, I figure I have less than a pint of capacity before I've got water backing up into places it shouldn't be (valve seats). Given the slow starting and long cranking required (before the carb rebuild), I think I was backing water up into the engine, hence the water in the oil.
I plan to build a proper exhaust riser with an injection elbow and get to going!
--Skagit out
Skagit is offline
post #38 of 43 Old 08-06-2013
skagit, when you question the exhaust design, is this a production boat or a backyard builder's home special?
post #39 of 43 Old 08-06-2013
Is there an anti siphone valve set up above the exhaust loop? If so is it working?
aa3jy is offline
post #40 of 43 Old 08-06-2013
bratzcpa's Avatar
Hey there Skagit. Where are you working on your project? Located at home on the hard . . . or Somers or Dayton? It would be fun to pop by and take a look sometime.
Regards,
markb
~markb
S/V "New Girl" on the dock
Catalina 27
bratzcpa is offline
Solid Fuel Stove Fuel HardTAC Gear & Maintenance 24 06-17-2013 08:15 PM
City marina to build self-service fuel station after three years without fuel - Corpu NewsReader News Feeds 0 07-16-2011 11:40 PM
I don't even know where to start. MariaDelMar Introduce Yourself 6 11-05-2009 08:47 AM
Where should I start dryclean General Discussion (sailing related) 5 06-07-2009 02:38 PM
Where to start, what to buy. puntapete Boat Review and Purchase Forum 16 11-05-2006 06:49 PM
