Fuel in oil - where to start? - Page 5 - SailNet Community
 3Likes
post #41 of 43 Old 08-06-2013
Re: Fuel in oil - where to start?
"Everyone is talking at me and I don't hear a word they say" Midnight Cowboy.
Water in the oil, 90% chance it is from the float needle valve leaking. After the valve is rebuilt, all the other problems should be less, or go away.
sony2000 is offline
post #42 of 43 Old 08-06-2013 Thread Starter
Originally Posted by hellosailor View Post
skagit, when you question the exhaust design, is this a production boat or a backyard builder's home special?
Hard to say. Looks production, but the boat is 40 years old, so who knows what's been done to it. It's not a good setup regardless...it just defies too much of the proper exhaust theory I've read about. There's just no room before it goes uphill, and it's ALL uphill from that little 6" bend. I'm going to do a dry riser so I can get at least 12" of vertical and inject the water on the downhill side, appx. 18" before the water lift. Also going to add a new water lift, since the one in there is probably original.
Originally Posted by aa3jy View Post
Is there an anti siphone valve set up above the exhaust loop? If so is it working?
No. No anti-siphon anywhere. That's another thing on the list. Even if that's not the problem, it's a good way to...you know...not sink, which is always the #1 goal of a sailing trip. That would go between the seacock and the water pump, right?
Originally Posted by bratzcpa View Post
Hey there Skagit. Where are you working on your project? Located at home on the hard . . . or Somers or Dayton? It would be fun to pop by and take a look sometime.
Regards,
markb
Hey Mark! Welcome back to cold country! I'll PM you and we can set up a time to get together. I'd like to know how your trip went.
--Skagit out
_____________________________________________
1975 Irwin 28 - hasn't earned a new name yet, but at this point it might not be flattering.
Skagit is offline
post #43 of 43 Old 08-07-2013
For fear of water coming back into the manifold at rest , I installed a solenoid type valve on the bottom of the aqua lift. Gets its power thru oil pressure switch from key and closes. Dumps to bilge when no pressure. Anti siphon is necessary regardless and an RV type black water valve at the transom for those big following seas under sail.
Capt Len is offline
Solid Fuel Stove Fuel HardTAC Gear & Maintenance 24 06-17-2013 08:15 PM
City marina to build self-service fuel station after three years without fuel - Corpu NewsReader News Feeds 0 07-16-2011 11:40 PM
I don't even know where to start. MariaDelMar Introduce Yourself 6 11-05-2009 08:47 AM
Where should I start dryclean General Discussion (sailing related) 5 06-07-2009 02:38 PM
Where to start, what to buy. puntapete Boat Review and Purchase Forum 16 11-05-2006 06:49 PM
