Under used Compass light circuit - SailNet Community
post #1 of 4 Old 06-30-2013 Thread Starter
One of None
deniseO30's Avatar
Been thinking. Gee, thanks Maine Sail! I'm a fearing me boat's gonna burst into flames any moment!
So I'm thinking about my boat's electrics in general. The compass light clearly can be used for GPS, maybe an led "map light" to shine over the swing up table. And, would my old autohelm 3000 be too much load?
Jus thinking with me fingertips here
My last project!
deniseO30 is offline
post #2 of 4 Old 06-30-2013
Re: Under used Compass light circuit
I'm thinking a map light would be fine along with any other lighting. How much does the auto-helm 3000 draw? You may want a dedicated circuit just for that. Running your GPS; sure.
The advantage to running different circuits is being able to par down your electric drain to what you will need at any given moment.
I prefer to run different circuits as possible. This way i only turn on what's absolutely necessary.
benesailor is offline
post #3 of 4 Old 06-30-2013
Most likely, the compass light is on the same circuit with the running (nav) lights. Look at the size of the wire and the load on the circuit. 12 AWG could have a 20Amp breaker and may suffice. On the other hand, running a new circuit from the panel to the cockpit isn't that much trouble.
Seaduction is offline
post #4 of 4 Old 06-30-2013 Thread Starter
One of None
deniseO30's Avatar
Thanks Sea, but no it's a separate circuit. #12 gauge If I remember right.
My last project!
Compass light Skipper Jer Gear & Maintenance 0 02-15-2013 03:26 PM
Compass light SouthBrooklyn Gear & Maintenance 1 10-31-2010 01:14 AM
Light indicator circuit needed when using starter battery macduff Electrical Systems 3 07-12-2009 10:51 PM
Compass Light 1970Columbia34 Gear & Maintenance 5 03-21-2007 10:21 AM
