Adler Barbour CU-100 short cycling - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 07-02-2013
One of None
deniseO30's Avatar
Re: Adler Barbour CU-100 short cycling
Really small units are really really difficult to charge by gauges Schock, just the hoses hold almost the same amount as the unit LOL Think it's an ounce per ft, if i remember right
My own home side by side called for I think it was 6 ozs of 134 when we replaced the compressor, after weighing in the right amount; I said "eh, it's not, right add some more" it's great except when the ac is off in the house and the kitchen gets really warm from summer heat and the head pressure climbs, and the inside temp struggles with ice cream
Point is, with 134 and refrigeration systems like these. They will get cold/freeze.. until later. much later. It takes quite some time for the pressures to stabilize when the little compressor is running if it's over charged. the discharge pressure will rise.. slow, very slowly. But yes, Schock, we all do it R-12 and other CFC freons still react faster then compounds like 134. I don't like it.. but it's here to stay
I still run R-12 in my old car it's great. It's weird sitting in a newer car or truck and waiting for the 134 to start cooling
My last project!
deniseO30 is offline
post #12 of 14 Old 07-02-2013
SchockT's Avatar
That's exactly why I DON'T like to charge by weight in small systems. The refrigerant in your gauges, and even the weight of your hoses themselves can affect the scale! Instead I charge the system, let it pull down with an empty box, and then adjust the charge so I have around 5-10 degrees of superheat at minimum load. It's the way the old fridge guru I apprenticed under taught me, and it has served me well.
I've never noticed any difference in "behavior" between R-134a and R-12. The 134a is about 10% more efficient, but they still change states and do their job in exactly the same way. I don't know what you mean by "react faster"?
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #13 of 14 Old 07-02-2013
One of None
deniseO30's Avatar
It just takes longer for the 134 to get up to operating pressures in auto air. mostly the retro fitted ones.
My last project!
post #14 of 14 Old 07-04-2013
SchockT's Avatar
bshock,
Have you resolved your problem, or learned anything new about it?
Hull#101
SchockT is offline
Frigoboat v. Adler Barbour mgraham49 Gear & Maintenance 7 02-20-2013 10:05 PM
Adler Barbour Condenser Fan dashman Gear & Maintenance 3 06-18-2012 08:05 PM
Adler Barbour refrigeration Fro36 Catalina 10 08-13-2010 09:42 AM
Adler Barbour PSI? recycle Gear & Maintenance 2 06-01-2008 11:59 PM
Adler Barbour maintenance ZapataII Gear & Maintenance 5 05-07-2008 01:01 PM
