Shower Sump - SailNet Community
post #1 of 4 Old 06-30-2013 Thread Starter
Shower Sump
I have replaced the shower sump pump, the check valve and cleaned or replaced the hoses on my shower pump out system Problem: the darn thing still won't work right. I hook everything up, turn it on and it works sort of once then no more! I remove a hoer at the pump, put it back on and it works once then no more. Frustrating at the least. Any ideas or suggestions??
Bump is offline
post #2 of 4 Old 06-30-2013
jsaronson's Avatar
Re: Shower Sump
When you say it does not work does the pump not turn on or it has I suction? If the later look for a clogged hose or filter or intake or a loose clamp
jsaronson is offline
post #3 of 4 Old 06-30-2013
Re: Shower Sump
How about the fitting at the shower floor? Corroded, hair ball ??
Most shower sumps work very slowly. Are you sure its not pumping at all?
Jeanneau 54DS
Minnewaska is offline
post #4 of 4 Old 06-30-2013
Stu Jackson's Avatar
Re: Shower Sump
You should have a vented loop in that system. Check to see if it is working.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
How-To for Shower Sump tomperanteau Columbia & Coronado 0 05-17-2011 03:42 PM
Endeavour 40 shower sump eskimo1941 Announcements and Suggestions Box 3 09-18-2009 08:06 PM
Air Cond to shower sump? Necessary or not Pamlicotraveler Gear & Maintenance 8 07-28-2008 04:12 PM
shower sump- catalina 30 capttack Gear & Maintenance 0 08-19-2004 05:50 AM
Installing a shower sump? AndrewB Gear & Maintenance 4 10-09-2001 07:31 AM
