Slow drip in seacock - to haul or not - SailNet Community
post #1 of 16 Old 06-30-2013 Thread Starter
We have a slow drip in one of our seacocks. Over the course of ten minutes it had one drip approximately every 90 seconds - 2 minutes. They are Spartan seacocks and the prior owner seemed to take great care of them. He re-greased them each year and they turn like butter. O.k., not so much now that we've tried to tighten it to stop the drip, but I digress...
The drip is coming from the two round washer-looking things to the right of the tightening bolt and locking nut. We think it's actually been doing this since we launched at the beginning of May, but ignorance was bliss.
Do you think this can wait until the end of the season, or should we haul the boat and fix it now? We are down there every weekend so we would certainly keep an eye on it, and we wouldn't open it for the rest of the season to try to keep from making it worse. It's the hose that leads from the sink, but we can live without the sink if necessary.
Thoughts?
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #2 of 16 Old 06-30-2013
fryewe's Avatar
Re: Slow drip in seacock - to haul or not
Should have a grease fitting (or a small plug on the valve body where a grease fitting can be installed). Grease it.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #3 of 16 Old 06-30-2013
Tartan 27' owner
CalebD's Avatar
Sink drain seacock?
does it leak when the valve is closed?
If it does not leak when closed then just leave it closed when not draining the sink.
If it does leak when closed then keep an eye on it. Try greasing it as suggested.
If grease doesn't work I might try a few thin threads of Butyl tape in there.
Everybody has one:
CalebD is online now
post #4 of 16 Old 06-30-2013 Thread Starter
We will definitely try more grease first. Boy, I really hope it's that simple.
If that doesn't work, however, how do we put the butyl tape in it when the boat's in the water? Sorry for the total newbie question!
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #5 of 16 Old 06-30-2013
In my opinion, if you have been able to verify that the leak is coming from the shaft of the seacock (and not say, from the hose to seacock joint), there is little or no risk of catastrophic failure.
What's happened is probably that the surface of either the rotating shaft, or the tube it sits in, is not smooth or is unevenly worn.
As long as it moves OK the likely scenario is that it continues to drip.
I changed one because the drip was soaking the teak cabin sole.
Where does your leak go?
I'm afraid that leaking of the taper-type seacock is rather common.
If it were my boat I would be comfortable with your plan to service it at the end of season. In fact I have done exactly that.
MarkSF is offline
post #6 of 16 Old 06-30-2013
MikeOReilly's Avatar
Disclaimer: I would want to personally look at it before giving any definitive suggestions.
However, I'd do the checks suggested by Mark et al. Snug the locking bolt, grease it, and keep an eye on it.
Every boat is sinking. It just depends on how fast. Assuming you have a decent bilge, and reasonable pumps, one drop a minute is nothing. 10 drops a minute is nothing. 60 a minute, I'm aware of, and will check occasionally. 600 drops per minute (a flow), I'll get concerned.
Do the maintentance. Keep an eye one it. Plan for a full investigation at the end of the season when you haul. Go sailing now.
Why go fast, when you can go slow.
MikeOReilly is online now
post #7 of 16 Old 06-30-2013
One of None
deniseO30's Avatar
I'd not put allot of torque on the nut could break the stud. Try to get some grease in there then re-tighten, but with a clamp. also while working the core back and forth. Warning! Do not let the valve and pipe rock as you work the valve core!
By the way, a band clamp can save the day in the case of a broken stud on a sea valve by holding the core in the valve body. Also, it appears to be the old style with a tapered core, not a ball type.
My last project!
deniseO30 is offline
post #8 of 16 Old 07-01-2013
I would be happier with a slightly leaky seacock that is moveable, than one where you have adjusted it so tight that it won't move properly, and doesn't leak.
I would re-adjust it so it moves OK and put up with the leak until the next haulout, provided it is indeed only a drip or two a minute.
MarkSF is offline
post #9 of 16 Old 07-01-2013 Thread Starter
Thanks for the suggestions, everyone. This is a great site when you're a newbie - I was actually able to sleep last night instead of worrying about the boat being on the bottom of the Sound when we see it again.
Mark, our drip is going to the same place. Judging from the condition of the sole in that area, I suspect it's been happening for some years now.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #10 of 16 Old 07-01-2013
Blue Horizons
Harborless's Avatar
Few things on a boat are as critical to its safe operation and not sinking than a seacock. i had a drip........drip coming from the stuffing box. It caused my boat to mold amd mildew out runing books, hts and lots of other things while making a foul odor. I would not haul for that alone but next time you need to do some work i would just buy a new marlon seacock and replace it. I replaced all six seacocks on my boat with marlon and they have been fantastic in every way. Just open and close them once every few months and back them with starboard. You will need a second set of hands for when you push the new seacock threough and someone else pushes the outside piece up into a fat glob of 5200.a
Harborless is offline
Seacock Drip (Spartan) Pamlicotraveler Gear & Maintenance 9 11-28-2012 03:26 PM
slow drip, seawater pump ereiss Diesel 12 07-25-2012 08:23 PM
Slow, slow, slow and menu not responding cupper3 SailNet FAQ 35 05-05-2012 06:30 AM
Stuffing box: To drip or not to drip? CalypsoP35 Gear & Maintenance 8 08-19-2011 12:30 AM
cruiseair drip QuickMick General Discussion (sailing related) 2 07-17-2011 04:52 AM
