plastic porthole windows - SailNet Community
post #1 of 12 Old 06-30-2013 Thread Starter
Hello,
I recently purchased a 1978 sailboat and am just starting to fix it up. One of the first things I'm looking to do is replace the plastic porthole windows as several are cracked. I've started to look around and have not found them yet. Wanted to see if anyone can point me in the right direction to find them.
Also wanted to get some suggestions on the the best sealant to for through haul penetrations.
Thanks
Blind Faith
Annapolis 26
mleiker is offline
post #2 of 12 Old 07-01-2013
rugosa's Avatar
Re: plastic porthole windows
Pictures would help -
rugosa is offline
post #3 of 12 Old 07-01-2013
Asleep at the wheel
jimgo's Avatar
Is this your boat?
ANNAPOLIS 26 (HOLMES) sailboat specifications and details on sailboatdata.com
Or is it the redesigned one (http://sailboatdata.com/viewrecord.asp?class_id=5586)?
You'll probably need to custom-cut them. It can be done at home, but it gets tricky if you haven't worked with the materials before. Another option is to go to a sign shop and ask them to cut them for you. You take off the old ones (try to keep them in one piece) and either take those to the shop, or make templates and take the templates to the shop. Personally, I'd opt for taking the real thing there.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #4 of 12 Old 07-01-2013 Thread Starter
Here are some pictures of the windows that I am looking for.
Sorry it took me so long to post them.
Blind Faith
Annapolis 26
mleiker is offline
post #5 of 12 Old 07-01-2013
Blue Horizons
Harborless's Avatar
Hello. I bought a 1979 and replaced both the ports in the head with beckson. They are great and easy to install yourself. They open up and have a screen to prevent insects from entering. The larger cabin port holes have been rebedded and will be replaced in time. The larger ones with acrylic are 180 per the smaller were less than that by a good deal. Try out Beckson you wont be sorry.
Harborless is offline
The Following User Says Thank You to Harborless For This Useful Post:
mleiker (07-01-2013)
post #6 of 12 Old 07-01-2013 Thread Starter
great!! Thanks, I will be sure to check them out.
Blind Faith
Annapolis 26
mleiker is offline
post #7 of 12 Old 07-01-2013
Asleep at the wheel
jimgo's Avatar
Sorry, I thought you meant the fixed ports.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
post #8 of 12 Old 07-01-2013 Thread Starter
no worries, thanks for replying.
Blind Faith
Annapolis 26
mleiker is offline
post #9 of 12 Old 07-01-2013
Another vote for Beckson (What port do I need? by Beckson). Worked well for me. (usual disclaimers - happy customer only).
Another alternative is to go with metal, Newfoundmetals (New Found Metals, Inc.) makes beautiful ports in stainless steel and bronze. Have a look at Installing New Found Metals Stainless Portlights Photo Gallery by Compass Marine at pbase.com - and that site is a totally awesome resource for many other things!!
Good luck
paul323 is offline
The Following User Says Thank You to paul323 For This Useful Post:
post #10 of 12 Old 07-01-2013
Stu Jackson's Avatar
Beckson port removal tool
Removing Beckson ports w/flix
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
The Following User Says Thank You to Stu Jackson For This Useful Post:
Porthole. Re-build steenbn Gear & Maintenance 3 08-11-2012 09:53 AM
Windows 7, Windows 8, work arounds and fixes svzephyr44 Electronics 5 07-02-2012 07:07 PM
porthole covers charlienpam General Discussion (sailing related) 7 06-13-2010 08:38 AM
Plastic paint for tired looking plastic parts Goodnewsboy Gear & Maintenance 3 01-01-2007 07:15 AM
Clear Plastic Windows Yodagwb Gear & Maintenance 1 05-30-2003 04:19 AM
