Crimping Different Guages question - Page 2 - SailNet Community
 11Likes
post #11 of 16 Old 07-02-2013
rhr1956's Avatar
Re: Crimping Different Guages question
Agreed...stranded wire should not be spliced in the above manner. I'll stick with the crimp connectors.
budvar likes this.
rhr1956 is offline
post #12 of 16 Old 07-05-2013
blutoyz's Avatar
I just strip the smaller wire back more and twist it over itself to increase the size. Then I use the crimp for the heavier gauge.
It may not be the "correct" way but has always worked for me
blutoyz is offline
post #13 of 16 Old 07-05-2013
asdf38's Avatar
The Western Union Splice or Lineman's Splice is intended for solid wire and should not be used on the finely stranded wire we use on boats. A Western Union Splice is an unsafe practice on finely stranded wire and can easily not hold or can fail pass the current needed in a safe manner...
I don't know why no one seems to want to use a terminal that is specifically designed for the job?
That's obviously the best. Is that Anchor brand? I havn't seen those exact ones before.
The problems I've encountered have been that 1) They're one more more thing to buy and 2) a lot of things don't even have 20awg wire, for example my compass comes with like 26 or 28, my spreader lights were 20 or 22, and the GPS was also 20+. So the cases where it's actually blue to red are somewhat rare.
Is there a good solution for blue to smaller than 20? I've gone with either twist and shrink wrap (not super robust but easy), or fold over and stick in a crimp designed for something bigger.
asdf38 is offline
post #14 of 16 Old 07-05-2013
Maine, you can't find those sexy proper connectors at the local hardware store!
But offhand...if a connector is big enough to fit 14/16 wire, and you slip one 16 and one 18 both into the same end of it...that's going to fit pretty nicely. So you strip a little more wire, feed them all the way through, crimp on both ends so you've got a double crimp in there as well. No big deal. Mail ordering the right connectors...an extra ten bucks for postage, an extra week to arrive...not an unforgiveable sin to kludge it for a one-shot job, when you're not equipping a shop for repeat work.
hellosailor is offline
post #15 of 16 Old 07-05-2013
redline's Avatar
I just fold the smaller wire back on itself, doubling it for the length of the crimp. With new LED fixtures and a boat whose wiring loom was sized for incandescent, this isn't uncommon. While I'm normally somewhat of an OCD perfectionist, I've never had any problem sizing the wire to fit the terminal in this manner. It also works when you have to use a ring terminal and the only ones large enough to fit the stud are oversize for the wire.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
post #16 of 16 Old 07-06-2013
bblument's Avatar
Or, you could do what the previous owner of my boat did... repeatedly....
Hold the wires next to each other, maybe twist'em once for good luck, then cover them with electrical tape, then sell the boat to me... sigh....
Barry
SOVT and budvar like this.
bblument is offline
Basic Crimping Question Jaywalker Gear & Maintenance 9 08-10-2010 08:56 PM
Crimping 2/0 lugs SteveInMD Electrical Systems 7 08-21-2009 06:19 PM
Guages with NMEA inputs... CharlieCobra General Discussion (sailing related) 0 06-14-2009 11:52 AM
Electrical Wire Crimping Tip montenido Gear & Maintenance 13 03-13-2009 02:19 PM
Trouble-shooting depth and speed guages billkidd Gear & Maintenance 0 08-20-2002 08:49 AM
