Crimping Different Guages question - SailNet Community
 11Likes
post #1 of 16 Old 07-01-2013 Thread Starter
budvar's Avatar
I'm switching the mast lights to LED. While the mast is down, figured would replace all the wiring ('82 US Yacht).
The LED lights vary from 18 to 20 gauge wiring. I'd like to use fourplex tinned 16 ga. as the mast wiring.
Everywhere I have looked, it seems like there are crimp connectors for 16-14 guage, and 18-20, but nothing to bridge the gap.
Am I missing something obvious here? How do I get a decent connection between 18 or even 20 to the the thicker 16 gauge wiring?
Thanks, from a nurse, not even an amateur electrician (until became a sailor).
Chris
Tri-Cities area (Columbia river), WA.
budvar is offline
post #2 of 16 Old 07-01-2013
Maine Sail's Avatar
Re: Crimping Different Guages question
You need a blue to red step-down butt connector.. It will be blue with a red stripe on the red end and both sides crimp with the blue die in the crimp tool.
sailak, rugosa and budvar like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 16 Old 07-01-2013
tommays's Avatar
You looking for a step down butt connector preferably one with good shrink tubing on it
budvar likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #4 of 16 Old 07-01-2013
Butt connector? Guys, he said he was a nurse, not a proctologist.
budvar likes this.
bnaylor is offline
post #5 of 16 Old 07-02-2013
Another solution would be a terminal block at the point where the cables meet. If this is at the mast base or some other logical place, much the better.
This kind of thing :
Terminal Blocks
budvar likes this.
MarkSF is offline
post #6 of 16 Old 07-02-2013
You can crimp a smaller wire in a larger terminal by filling the remaining space with copper strands from an off cut of wire - ideally an off cut from the same size wire. Pack as many strands in as possible then crimp.
budvar likes this.
Tymadman is offline
post #7 of 16 Old 07-02-2013
Google "sherco automotive" and search for Hydralink. They work well and have integral heat shrink. Also good for butting two wires to one. No affiliation just satisified customer.
Or
http://www.sherco-auto.com/hydralink.htm
Goodwinds
DaveM
dsmauney is offline
post #8 of 16 Old 07-02-2013
rhr1956's Avatar
Put both the smaller wire and the larger wire in the same end of a properly sized butt connector. Just use the one end of the connector. Shrink tube the whole thing when done. Works fine.
rhr1956 is offline
post #9 of 16 Old 07-02-2013
chucklesR's Avatar
I know it's not the certified method but...
Just do a modified western splice ( hold the wires at 90 degrees and twist, once you are done fold that back along the wire. Tape it, heat shrink it, done). No need for an expensive one of a kind butt connector.
chucklesR is offline
post #10 of 16 Old 07-02-2013
Maine Sail's Avatar
The Western Union Splice or Lineman's Splice is intended for solid wire and should not be used on the finely stranded wire we use on boats. A Western Union Splice is an unsafe practice on finely stranded wire and can easily not hold or can fail pass the current needed in a safe manner...
I don't know why no one seems to want to use a terminal that is specifically designed for the job?
budvar likes this.
______
Basic Crimping Question Jaywalker Gear & Maintenance 9 08-10-2010 08:56 PM
Crimping 2/0 lugs SteveInMD Electrical Systems 7 08-21-2009 06:19 PM
Guages with NMEA inputs... CharlieCobra General Discussion (sailing related) 0 06-14-2009 11:52 AM
Electrical Wire Crimping Tip montenido Gear & Maintenance 13 03-13-2009 02:19 PM
Trouble-shooting depth and speed guages billkidd Gear & Maintenance 0 08-20-2002 08:49 AM
