Westerbeke/Universal Diesel Problems - SailNet Community
 7Likes
post #1 of 19 Old 07-01-2013 Thread Starter
I canít get the marine diesel engine (3 cylinder Westerbeke/Universal 25 HP) on my sailboat to keep running. When cold, it starts ok and runs for about 1 Ė 2 minutes, then sputters and shuts off. It runs a little longer at low RPM than high RPM. After this short run and sputtering off, the engine wonít start again, it just sputters with the assistance of the starter. After the engine has sat a while, 20 minutes or so, the same thing happens again. The starter cranks the engine over just fine. Iíve thoroughly checked the fuel system and it seems to work ok. I have done the following:
Replaced the Raycor prefilter coming out of the fuel tank (the fuel looked clean but I replaced it anyway)
Replaced the fuel lift pump (the ďoldĒ one was only about 3 years old, looked like new and seemed to pump just fine)
When the glow plug button is pressed, one can hear the fuel lift pump working, just like on the original.
Replaced the fuel filter between the fuel lift pump and the injector pump
Bled the air (the system is supposed to be self bleeding, but I hot wired the lifter pump and manually bled anyway at the fuel filter between the lift pump and injector pump)
Pulled off lines between injector pump and injectors and observed fuel coming out of injector pump, no air bubbles.
Opened up the injectors and cleaned the jets Ė they were a little sooty, but not overly so.
I hot wired the lifter pump and heard fuel flowing through the overflow lines at the top of the injectors and dropping back into the fuel tank, as normal.
I have a vacuum gage between the Raycor filter and the fuel lift pump, and the gage shows 0 psi, no problem there.
What is the problem? The engine was very reliable till the onset of this problem from one outing to the next. I canít think of ANYTHING we did between outings that should cause this. Is there a thermostat or something else somewhere that is shutting down the system? If so, what is it and where is it on this engine? The engine runs for such a short time that it is still cold to the touch. HELP!!!
stowe18 is offline
post #2 of 19 Old 07-01-2013
Re: Westerbeke/Universal Diesel Problems
double check connections and condition of oil pressure switch...forward right of block...believe this is the part number..Westerbeke Oil Pressure Switch 37323 037323 | eBay
messenger is offline
The Following User Says Thank You to messenger For This Useful Post:
stowe18 (07-01-2013)
post #3 of 19 Old 07-01-2013
One of None
deniseO30's Avatar
The fuel pickup tube in your tank. check it. very overlooked and almost always sludge clogged, even in clean tanks.
Familycruisers and wymbly1971 like this.
My last project!
deniseO30 is offline
The Following User Says Thank You to deniseO30 For This Useful Post:
post #4 of 19 Old 07-01-2013
Familycruisers's Avatar
From your description definitely fuel flow. Think Denise might have a winner.
deniseO30 likes this.
S/V Never Land
Westerly Centaur
Familycruisers is offline
The Following 2 Users Say Thank You to Familycruisers For This Useful Post:
deniseO30 (07-01-2013), stowe18 (07-01-2013)
post #5 of 19 Old 07-01-2013 Thread Starter
How do you get it out to look at it?
stowe18 is offline
post #6 of 19 Old 07-01-2013 Thread Starter
I'll definitely do that .. Thanks for your help!
stowe18 is offline
post #7 of 19 Old 07-01-2013
One of None
deniseO30's Avatar
If you tell us what boat/model you have maybe someone has the same boat and would know more. Most pick up tubes come out with the fitting that threads into the top of the tank. How do I know? BEEN THERE DONE THAT! LOL
My last project!
post #8 of 19 Old 07-01-2013 Thread Starter
Why wouldn't the vacuum gauge (attached prior to the fuel lift pump) show a vacuum? The fuel tank was cleaned 3 years ago. It was NOT easy to get into!
stowe18 is offline
post #9 of 19 Old 07-01-2013 Thread Starter
Denise - will the screen come out through that hole?
stowe18 is offline
post #10 of 19 Old 07-01-2013 Thread Starter
By the way, its a 1986 35' O'Day, replaced with a new engine in 1998. The original engine was a 21hp bronze color Universal. The new engine is a silver painted Westerbeke 25 hp.
stowe18 is offline
Tags
diesel engine , universal
Diesel fuel lines -Universal 3cyl diesel argofred Diesel 8 04-18-2011 03:39 PM
Universal/ Westerbeke Warning Buzzer 1970Columbia34 Gear & Maintenance 1 06-16-2009 10:14 AM
Westerbeke 27 Starting problems 82Sabre34 Gear & Maintenance 2 05-25-2009 01:18 PM
Heat Exchangers - Up Close & Exposed (Westerbeke/Universal) Maine Sail Gear & Maintenance 24 01-19-2009 11:53 AM
Westerbeke/Universal kccollbran Gear & Maintenance 1 08-03-2008 06:15 AM
