Rounded bolts and/or nuts - SailNet Community
 1Likes
  • 1 Post By PAULCR1
post #1 of 5 Old 07-01-2013 Thread Starter
PAULCR1's Avatar
I don't know if it's o.k. to mention a specific product or not but I'll try. I had a 17mm bolt that ran into the rear of my Universal engine. The bolt held a bracket that had rusted through. First I applied PB Blaster, WD40, acetone/trans fluid mix and heat then I tried a 17mm box wrench and it just rounded it, the bolt, off. I then bought a set of open end/box wrenches that had inserts in them that were held in by plastic. First try it failed. Tore the insert right out. Sent them back. I then remembered Craftsman. They make a product called "BOLT-OUT". If you don't have this set on your vessel you are making a big mistake. It works great. First time. It is like a socket with a tapered reverse helix. Just thought I'd pass the info along. Maybe it'll help someone else.
jimgo likes this.
Theodore Roosevelt said In any situation, the best thing you can do is the right thing; the next best thing you can do is the wrong thing; the worst thing you can do is nothing.
PAULCR1 is offline
The Following User Says Thank You to PAULCR1 For This Useful Post:
arf145 (07-02-2013)
post #2 of 5 Old 07-02-2013
Irrationally Exuberant
Re: Rounded bolts and/or nuts
Those do look like they could be lifesavers. I might add a set to my tools!
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #3 of 5 Old 07-02-2013
One of None
deniseO30's Avatar
On Stainless which is like putty under wrenches..
My last project!
deniseO30 is offline
post #4 of 5 Old 07-02-2013
TQA
Bombay Explorer 44
TQA's Avatar
Take a Snap On socket slightly smaller than the rounded off nut/bolt.
Hammer it on
Remove nut/bolt.
If socket damaged return to Snap On for a replacement.
TQA is offline
post #5 of 5 Old 07-03-2013
I don't discuss my member
zz4gta's Avatar
They're called easy outs.
Merit 25 # 764 "Audrey"
zz4gta is offline
Older CCA boats with rounded robust overbuilt booms...added boom vang needed? souljour2000 General Discussion (sailing related) 23 06-11-2016 07:43 PM
keel nuts- rusty can you replace just the nuts nikksandy Gear & Maintenance 10 04-27-2010 03:01 PM
Keel nuts, bolts, loctite, et al.. rperret Gear & Maintenance 1 04-27-2008 11:23 PM
nylon nuts and bolts grampian23 Gear & Maintenance 2 02-20-2004 04:48 PM
