Halogen to LED - Page 2 - SailNet Community
post #11 of 21 Old 07-02-2013
72 C&C Corvette
CorvetteGuy's Avatar
Re: Halogen to LED
Don't touch lights cause they are hotter than you fingers led, incandescent or other wise,, but led's do draw less power.
CorvetteGuy is offline
post #12 of 21 Old 07-02-2013
JimMcGee's Avatar
Re: Halogen to LED
I'll jump on the bandwagon. I replaced all our bulbs with LED's two seasons ago. As long as you go with warm white you should be happy.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #13 of 21 Old 07-02-2013
Re: Halogen to LED
Agree with warm white. Even the natural white is a little too blue for my taste. The cool white is way too blue.
Catalina 34
chuck53 is offline
post #14 of 21 Old 07-02-2013
Re: Halogen to LED
LED's will probobly last longer too, you should not have any problems on an electrical system going downwards in total power usage.
Spider0804 is offline
post #15 of 21 Old 07-02-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Halogen to LED
Originally Posted by chuck53 View Post
I replaced a bunch of festoon bulbs with their LED equivalent. Just for the heck of it, I pulled out my little temp gun I keep on the boat. The regular festoon bulbs were in the 150-160 degree range. All my LED's were less than 90 degrees.
Festoon or LED strips attached directly to a surface often, maybe even usually, build up heat in the back of the diode rather than the front. Its why heat can be a problem. Unless the rear is ventilated they can, emphasise on can, overheat. When I use LED strip I always like to put it in an aluminium extrusion with a diffuser. Better (well at least more confortable) light and the extrusion assists in heat dissipation.
LED lamps will most definitely be cooler to the touch than halogen or incandescent festoon lamps, I am not saying otherwise. What I am saying is that many users underestimate just how much heat they do put out and that this heat is often backwards not forwards as per most other light sources. over heating of LEDs will shorten lamp life.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #16 of 21 Old 07-02-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Halogen to LED
most LEDs have a high "infant mortality rate". The one place I work, Harrah's Atlantic City, has their own tower covered in programmable LED lighting. During the day we turn the intensity down so it cannot be seen, but if we actually turned the things off, they would die more often when first turned on
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #17 of 21 Old 07-04-2013
mitiempo's Avatar
Re: Halogen to LED
Originally Posted by Gregrosine View Post
That's what I am thinking, but I am questioning if there will be any issues with the change in amp load that I have to be concerned about.
There will be a large difference in load - you will use less amps.
Brian
mitiempo is offline
post #18 of 21 Old 07-08-2013
Closet Powerboater
MedSailor's Avatar
Re: Halogen to LED
Sounds like warm white is the way to go.
Anyone have favorite brands or places to buy them? The last time I seriously looked at LED replacements (years ago) they were very blue, and very expensive....
MedSailor
MedSailor is offline
post #19 of 21 Old 07-08-2013
Senior Slacker
SlowButSteady's Avatar
Re: Halogen to LED
MedSailor
Boat/RV/Other LED Replacement Bulbs | Boat, RV, and Other Lighting | Super Bright LEDs
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
The Following User Says Thank You to SlowButSteady For This Useful Post:
MedSailor (07-08-2013)
post #20 of 21 Old 07-09-2013
Re: Halogen to LED
Warm white is a term used with abandon by LED manufacturers. It's essentially meaningless. They are usually honest about actual specs though, so look for the colour temperature. Incandescent is 2700K. LEDs of 3000K or less produce a pleasant light. Much higher, though and it's getting cold and blue.
I've seen 5500K described as warm white on Ebay.
MarkSF is offline
New Halogen is acting strangely. L124C Electrical Systems 29 02-16-2011 08:15 AM
