Halogen to LED - SailNet Community
post #1 of 21 Old 07-01-2013 Thread Starter
Gregrosine's Avatar
Halogen to LED
Other than he physical size issues are there any electrical concerns with switching from halogen interior cabin lights to LED lights? Can I just pull out the halogens and rewire in the LEDs? I'm thinking it would save a load on power demands.
Gregrosine is offline
post #2 of 21 Old 07-01-2013
Re: Halogen to LED
Why not just keep the fixture and replace the Halogen bulb with an LED equivalent?
Catalina 34
chuck53 is offline
post #3 of 21 Old 07-01-2013 Thread Starter
Gregrosine's Avatar
Re: Halogen to LED
That's what I am thinking, but I am questioning if there will be any issues with the change in amp load that I have to be concerned about.
post #4 of 21 Old 07-01-2013
s/v Tiger Lily
dvuyxx's Avatar
Re: Halogen to LED
There shouldn't evany problems with the load if it going down (smaller load). We replaced all of the halogen and incadescents with LED replacements. Overall not as bright, but the lower draw (1/10th of previous) is worth it. Be sure to get WARM color LEDs. They don't have that cool electric blue hue which is odd and unnatural.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #5 of 21 Old 07-01-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Halogen to LED
Your halogens are presumable 12v 20w .... 1.66 amp each. No way your LEDs will exceed that.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #6 of 21 Old 07-01-2013
Re: Halogen to LED
One nice advantage to LED's, they don't put out the heat of a Halogen. Much cooler to the touch.
Catalina 34
chuck53 is offline
post #7 of 21 Old 07-02-2013
tdw
tdw's Avatar
Re: Halogen to LED
True but don't kid yourself that they don't produce heat. The best LEDs for mains voltage usage have whacking great heat sinks to disperse some of that heat. One of the major causes of LED individual diode failure is overheating.
In a boat this is probably not an issue unless the LED lightsource is in too tight an enclosure.
― Terry Pratchett.
tdw is offline
post #8 of 21 Old 07-02-2013
Re: Halogen to LED
I replaced a bunch of festoon bulbs with their LED equivalent. Just for the heck of it, I pulled out my little temp gun I keep on the boat. The regular festoon bulbs were in the 150-160 degree range. All my LED's were less than 90 degrees.
Catalina 34
chuck53 is offline
post #9 of 21 Old 07-02-2013
Irrationally Exuberant
Re: Halogen to LED
Replaced every one of our interior bulbs with Marinebeam LED replacements. Way fewer amps being used and less heat being generated--can't find a worry in that.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #10 of 21 Old 07-02-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Halogen to LED
I have an LED flashlight that gets warm to touch if it is on for a couple of minutes
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
New Halogen is acting strangely. L124C Electrical Systems 29 02-16-2011 08:15 AM
