Refill Propane? - Page 2 - SailNet Community
 3Likes
post #11 of 12 Old 07-02-2013
Re: Refill Propane?
Originally Posted by arf145 View Post
....Related question: the tank has a pressure gauge. Does this in any way tell me how full it is?
Even if the tank guage was calibrated and reliable, pressure increases with temperature, so its not a good indication of volume. Chef is right, most accurate at zero.
If the pressure gauge comes after the regulator, its not tank pressure, but regulated pressure. That shouldn't change at all, when pressurized, until the tank is empty. It can be useful, if installed after the solenoid, to see if your system is holding gas after everything is shut off. However, if not testing, you should always burn off the excess gas in the hoses, by shutting off the solenoid with the burner on and letting it burn off.
chef2sail likes this.
Jeanneau 54DS
Minnewaska is offline
post #12 of 12 Old 07-02-2013
chef2sail's Avatar
Re: Refill Propane?
+1 good point about shutting the solenoid of first and letting the gas burn off
I have to remind the first mate all the time.
Also if you pizo electric sparkers have worn out and you use a firestarter wand, light the wand first before turning the gas on on the stove.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
CNG refill on Chesapeake? blakew1 Chesapeake Bay 5 08-26-2010 07:14 PM
Propane to CNG MDDesperado Gear & Maintenance 5 01-18-2008 04:41 PM
CNG refill tsaa Gear & Maintenance 1 10-10-2001 07:14 AM
compass refill grey99 Gear & Maintenance 3 07-14-2001 05:51 AM
