Diaphragm pump: care & maintenance - SailNet Community
post #1 of 11 Old 07-03-2013 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Diaphragm pumps: care & maintenance
I find that eventuallly the rubber seals on manual diaphragm-type bilge pumps start cracking, presumably from lack of use.
What do you guys do to prevent the rubber perishing? Is there something product or process that can be used to keep it supple??
Thanks,
C.
Classic30 is offline
post #2 of 11 Old 07-04-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Diaphragm pumps: care & maintenance
Thanks,
C.
With the HartleBoat being timber surely your bilge pump never lacks for use ?
ahem ...
To be frank I've never had the problem. The Womboat's manual pump has a ten year old diaphram, rarely used and not showing any sign of perishing.
Otoh I have heard that a smear of vaseline may help.
cheers
andrew
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #3 of 11 Old 07-04-2013 Thread Starter
Classic30's Avatar
Dock
Just wanting to make sure an item of Infrequently-Used Essential Safety Equipment (thank you very much!) remains in top working order in readiness for that fateful Day one hopes will never come...
A smear of Vaseline helps many things... but, good-o, I'll do that.
PS: I'm looking forward to the day I don't have to walk into a Chemist shop (that's "drug store" in American - over here the words "drug store" mean something else entirely!!) to buy a tub of Vaseline, since the looks from the staff at the checkout are anything but flattering.
Perhaps I should ask Mrs H to buy it instead??
post #4 of 11 Old 07-05-2013
Tartan 27' owner
CalebD's Avatar
Re: Diaphragm pump: care & maintenance
Not preparation H but KY jelly would do...
Ask for petroleum jelly and there'll be no raised eyebrows.
Everybody has one:
CalebD is offline
post #5 of 11 Old 07-05-2013
Remember you're a womble
PaulinVictoria's Avatar
Should you put a petrol based lubricant on a rubber diaphragm? Doesn't that eventually cause it to break? (hence why you don't use vaseline on condoms).
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #6 of 11 Old 07-05-2013 Thread Starter
Classic30's Avatar
Dock
Good point (you've some experience with this, Paul? )
If not "petroleum jelly", then what? Nothing(TM)??
post #7 of 11 Old 07-05-2013
jjablonowski's Avatar
Go to your local automotive parts store and get some tire protectant/dressing.
Joe - s/v Assignment, Catalina 320
jjablonowski is offline
post #8 of 11 Old 07-05-2013
Señor Member
PorFin's Avatar
You should also be able to find silicone grease -- look in the plumbing section of a hardware store. Very standard to use it to lube/seal o-rings.
Since K-Y (like most "personal lubricants") is water soluble, I'd probably give that one a miss.
________
'85 BYB Vagabond 39
PorFin is offline
post #9 of 11 Old 07-07-2013 Thread Starter
Classic30's Avatar
Dock
Thanks guys. Two sensible options that are probably much the same thing.
I've got silicone grease on board already and will give that a go.
post #10 of 11 Old 07-07-2013
Over Hill Sailing Club
smurphny's Avatar
+1 on the tire protectant. I've also had the same question about pump diaphragms. The one I took out when doing the refit was dried out and cracked. It would be nice to be able to protect the 2 new ones with something. I hope someone chimes in here with an actual product made just for this purpose. Petroleum-based products could do more damage than help over the long run. I also have some old Jabsco pumps with diaphragms that have required replacement because of dried out rubber. Maybe Armor-All, the stuff used on dashboards and car body parts??
smurphny is offline
Re: Par Diaphragm Pump NewsReader Mass Bay Sailors 0 02-22-2007 01:15 PM
Par Diaphragm Pump NewsReader Mass Bay Sailors 0 02-22-2007 11:15 AM
