Going up the mast on a trailerable sailboat? - Page 3 - SailNet Community
 4Likes
post #21 of 24 Old 07-05-2013
bristol299bob's Avatar
Re: Going up the mast on a trailerable sailboat?
SunnyD have you considered making a "test harness"? You'd need compatible connectors and a length of wire. With the mast lowered you could plug one end in to the base on the boat, the other end into the base at the mast. then you can test all day long from the comfort of ground level.
bljones likes this.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #22 of 24 Old 07-05-2013
jppp's Avatar
Uhh.. tip it over with the main halyard.
1985 C&C 35 MK 3
jppp is offline
post #23 of 24 Old 07-06-2013 Thread Starter
Location: Boat is in a slip at Kentucky Lake; we live in Clarksville, TN
Ladder? Now where is the fun in that? I guess I could combine the two options and put on a harness attached to the halyard as a backup safety in case the ladder falls or I lose my balance. And here I go overcomplicating things again.
See, now I have three options. I still have to check the heights and see if there is a flat, safe place to put the base of a ladder but that could definitely work as well (at least for the initial inspection to determine the problem).
SunnnyD is offline
post #24 of 24 Old 04-06-2014 Thread Starter
Just an update to my post a while back... ended up borrowing a bosun chair from a neighbor, and used the jib/main halyards to go up the stick (lost my spinnaker halyard). The boat was tied off to the dock so it didn't move much, and it was a calm day. I pretty much just pulled the main halyard while a helper pulled in the slack around a winch and through a cam cleat, and up I went.
davidpm likes this.
SunnnyD is offline
The Following User Says Thank You to SunnnyD For This Useful Post:
Donna_F (04-06-2014)
Tags
bosun's chair , running light , safety , trailerable
Largest Semi-Trailerable Sailboat ??? Kyhillbilly General Discussion (sailing related) 115 12-24-2013 06:25 PM
Looking for a Trailerable Sailboat Shakin97 Boat Review and Purchase Forum 12 10-31-2011 10:28 AM
biggest trailerable sailboat operator235 Boat Review and Purchase Forum 31 11-04-2009 08:49 PM
Two-Person Trailerable Sailboat GoLikeaFish Boat Review and Purchase Forum 2 09-08-2006 03:12 PM
Largest trailerable sailboat bayme Boat Review and Purchase Forum 11 03-10-2004 03:34 AM
