Handling Anchor/Rode with no Locker - Page 4 - SailNet Community
 4Likes
post #31 of 42 Old 10-29-2013 Thread Starter
asdf38's Avatar
Re: pail
Originally Posted by Group9 View Post
I do the same thing with my secondary anchor rode (all but the chain). It works pretty well.
My shackle is ceased shut and I was about to pry it open when it occurred to me that I should probably have monel ceasing wire on hand to secure it in the future. Well I haven't gotten that yet so I've just left the chain attached.
When you shackle and unshackle are you using ceasing wire or anything else?
asdf38 is offline
post #32 of 42 Old 10-29-2013
Delta-T's Avatar
Re: Handling Anchor/Rode with no Locker
This is what has been on my boat for 44 years, has never leaked. Made for securing the chain (you should have chain leader) through the deck and has a hook on the underside of the cover to hold the cover down and chain up.
http://www.boatersland.com/sdg322070.html?gclid=CL6A6Oi2vLoCFel_QgodaH0AMQ[/IMG]
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #33 of 42 Old 10-29-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: pail
you may want to consider some anti-seize on that shackle with the wire. you may never know when you want to take it apart
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #34 of 42 Old 10-30-2013
Singlehander by Default
nighthawk's Avatar
This is what I have on Wind Angel. I like the setup and it works well. Especially like the chain hook on the underside since I usually travel with the rode unattached and anchor tied down seperately. My issue is with an overly small stowage area underneath the cover.
Spencer
Laguna Windrose 22 "Wind Angel"
Catalina 16
Visit my blog--
~~When you decide to become a sailor, you start with a full barrel of luck and an empty cup of experience. The trick is to fill your cup before the barrel runs dry.~~
nighthawk is offline
post #35 of 42 Old 10-30-2013
Group9's Avatar
Re: pail
Usually cable ties.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #36 of 42 Old 10-30-2013
bfloyd4445's Avatar
Re: pail
Usually cable ties.
I admit I have used cable ties also but they often break and we shouldn't use them. Better to use wire. I've been thinking of using locktite. Locktite holds really well and can be undone with a wrench.
bfloyd4445 is offline
post #37 of 42 Old 10-31-2013
Group9's Avatar
Re: pail
True. The reason I use cable ties is that they are easy to keep handy, are easy to use, and easy to cut loose when you are done.
Most of the time, what causes cable ties to break, is due to UV exposure and breakdown. Using black cable ties, and the fact that they are underwater, both help this from being as serious an issue. They can be cut and abraded, but not that easily.
Group9 is offline
post #38 of 42 Old 10-31-2013
Delta-T's Avatar
Walmart carries stainless steal cable ties. Of all places to find something like that for a reasonable price!! Kind of like a CV boot clamp on a car or Quad. They started carrying then in the last year. Garden Bender 11" Cable Tie, 100 lb, Stainless Steel, 10pk: TV & Video : Walmart.com
Eric
Delta-T
Delta-T is offline
post #39 of 42 Old 10-31-2013
Group9's Avatar
That's what I like about his site! Thanks, I'll be checking those out.
Group9 is offline
post #40 of 42 Old 08-07-2014 Thread Starter
asdf38's Avatar
So it's over a year later and one small improvement I settled on was to buy a nylon log carrier (about $12 on Amazon) to carry both the anchor and the rode.
I think this is a pretty decent idea which will make my life easier.
I also replaced the rode on my bigger anchor, which was over-sized by about 2 sizes on both chain and rode. And it wasn't even that long (150') yet was incredibly heavy and bulky.
With the new defender pre-made 1/2" 8-plait 215' rode, which is much more compact, I'll be able to move the bigger anchor and rode from the V-birth to the bilge under the cabin floor - in the log carrier. Not perfect but still pretty quick to retrieve , and far better than under the V-birth cushions.
The small anchor (which also has an incorrectly sized rode - but is too small), still lives in the cockpit locker.
asdf38 is offline
anchor rode issues RandyonR3 Beneteau 4 03-21-2013 10:47 AM
E32 anchor locker mod Ritchard Endeavour 2 07-09-2012 08:24 AM
Crealock 37 Anchor Locker BirdBrain333 Pacific Seacraft 5 11-18-2010 05:54 PM
Anchor Rode Length sailjunkie Gear & Maintenance 14 03-22-2010 08:09 PM
anchor rode maestro Gear & Maintenance 9 06-19-2005 11:38 AM
