Loosing power Universal M25XP - SailNet Community
 1Likes
  • 1 Post By Sal Paradise
post #1 of 9 Old 07-04-2013 Thread Starter
When running the engine at more than say half speed my engine starts to loose power and RPM's. It seems to run fine at lesser speeds but as soon as I kick it up it starts to die out and even stall. Waiting a while will allow the engine to start again but soon I am stalling out again if I push it. I have had the fuel tank cleaned, the fuel polished and the air filter replaced. Yes all three were a mess. Any ideas??? Going to talk to my mechanic soon but would like to have some idea as to what can be causing this problem.
Bump is offline
post #2 of 9 Old 07-04-2013
One of None
deniseO30's Avatar
Re: Loosing power Universal M25XP
Pick up tube, it's always overlooked and has a fine mesh strainer on the end.
My last project!
deniseO30 is offline
post #3 of 9 Old 07-04-2013
You didn't mention replacing the fuel filter. Just because the fuel has been polished doesn't mean your filter isn't clogged.
Catalina 34
chuck53 is offline
post #4 of 9 Old 07-04-2013
Captain Obvious
Sal Paradise's Avatar
fuel filter
change it.
34crealock likes this.
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #5 of 9 Old 07-04-2013
I am having the same problem, but it bogs down but does not actually stall. I think that I am getting air into the fuel system, but not sure from where.
2001 Catalina 310
eSailor is offline
post #6 of 9 Old 07-04-2013
Learning the HARD way...
eherlihy's Avatar
Check the filter on the electric fuel pump.
eherlihy is online now
post #7 of 9 Old 07-06-2013
There should be two filters - one on the fuel pump, and the pre-filter.
MarkSF is offline
post #8 of 9 Old 07-06-2013
H2814D's Avatar
Could be a few things actually. In addition to the above posts, how does the temperature look? An overheating engine will stall. Also, do you have a vented fuel tank? If the vent is clogged it could be restricting the fuel flow. After experiencing the problem, start taking the fuel cap off slowly and see if there is a suction of air sound. If so, find out where the vent is and make sure it is clear. You can also diagnose this one by loosening the cap while running and see if the engine speeds return to normal. Too many things to be sure, so get to work. :-)
H2814D is offline
post #9 of 9 Old 07-07-2013
ebs001's Avatar
I had a similar problem with my X25. It turned out to be the electric lift pump which was working intermittently. Replaced it and everything was fine. You can get a replacement pump at NAPA.
ebs001 is offline
Universal M25 losing power eherlihy Diesel 35 11-08-2012 05:18 PM
Universal M18 Power Loss GrumpyPawPaw Diesel 5 08-06-2012 06:24 PM
Universal M25XP / Kubota D950 question kaptaindave Gear & Maintenance 8 12-02-2009 12:39 PM
Universal M25XP for sale inshallamiami Gear & Maintenance 1 02-02-2009 01:38 PM
Re-power with universal diesel bayme Gear & Maintenance 3 01-25-2009 10:41 AM
