furling and hallyard wrap. - SailNet Community
 1Likes
  • 1 Post By oysterman23
post #1 of 3 Old 07-05-2013 Thread Starter
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Schaefer snapfurl 500 got jammed up the otheer day made some adjustments on the lower drm and then today it all just went terminal..wouldn't roll out or in fully on returning to berth it was clear there was a. Halyard wrap up above understand likely remedy is a halyard retainer but any suggestions on approach to freeing it up prior to necessary changes?
Thx
Chris
deltaten likes this.
oysterman23 is offline
post #2 of 3 Old 07-05-2013
Re: furling and hallyard wrap.
My furler eliminates that problem by eliminating the halyrd swive,l for a block on the side of the extrusion. You hoist the sail, tie the end of the halyard to the drum, take the rope tail off, and tighten the luff with a downhaul on the drum . The halyad block and all rotate with the furlr. A friend, working for a rigger, said a lot of people were doing that with commercially made furlers .
Brent Swain is offline
post #3 of 3 Old 07-05-2013
overbored's Avatar
happens mostly when halyard is not tight you will need to undue the warp by turning the drum until the warp is clear. the halyard retainer is use to increase the angle of the halyard to the swivel. should be at 15 degrees. if you use a shorter head sail it should have a wire or rope pennant so the swivel will be at the same height
"GOLD RUSH" PRINDLE 16
overbored is offline
Roller Furling Halyard Wrap ebs001 Gear & Maintenance 10 03-18-2013 11:06 AM
Shrink Wrap Atlantic Salt Gear & Maintenance 6 11-19-2012 10:57 AM
Question about in-boom furling & in-mast furling KIVALO General Discussion (sailing related) 3 03-27-2012 09:33 PM
Saran Wrap svzephyr44 SailNet FAQ 6 03-01-2012 06:40 AM
shrink wrap NewsReader Mass Bay Sailors 2 05-05-2011 11:10 PM
