Should a Roller Furler be Hard? - Page 3 - SailNet Community
 16Likes
post #21 of 30 Old 07-10-2013
chef2sail's Avatar
Re: Should a Roller Furler be Hard?
Originally Posted by T37Chef View Post
Dont over do it though or you could jam it
Sorry folks, inside joke
Ha...only you can jam it
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #22 of 30 Old 07-10-2013
Mermaid Hunter
SVAuspicious's Avatar
+1 on SailKote.
Furling line lead issues are unlikely to have the symptoms described by the OP.
I'm thinking too much halyard tension.
SVAuspicious is offline
post #23 of 30 Old 07-10-2013
Should be eezy peezy to look up at the head of the jib to see if its halyard wrap or not, aye?
chef2sail and OZWILD like this.
Seaduction is offline
post #24 of 30 Old 07-11-2013 Thread Starter
Thanks everyone for your input and suggestions. I released some of the tension on the jib halyard (had it super tight from my old hank on days) and actually raised the sail a bit more up the foil closer to the mast top. This seems to have done the trick.
Thanks again,
Frank
T37Chef and OZWILD like this.
fharbison is offline
post #25 of 30 Old 08-18-2014
Been reading through these and other threads and have a few things to check out. That said, I have an Endeavour 38 and it has a Harken Mk IV I think but the drum is the smaller one. I have not found any boats my size with one this small. When I bought the boat a couple years ago the surveyor noted this and when talking to him he said he would prefer the larger but would just use it. The furling line though small fills the drum with the 150% I have on it. Played with that some seeing if I could find the right amounts. The small line is tough on the hands when pulling it in. It unrolls fairly good but it any breeze at all it takes all you got to pull it in. If the wind picks up your not going to get it in unless on a winch which know should not have to do. You have to be very careful not to get the line jammed in the drum. Just wonder if it's too undersized for this boat and needs the next size. The PO may have just been trying to save so $$. Any thoughts appreciated
Another Day
Another Day
Endeavour 38
Mobile, AL
last mango is offline
post #26 of 30 Old 08-18-2014
The sudden difficulty in rolling up is not likely to be friction. I suspect that there is something wrapping or binding somewhere.
Rockter is offline
post #27 of 30 Old 08-19-2014
JimMcGee's Avatar
If you suspect the jib halyard has wrapped around the forestay you should either drop the rig and inspect it or have someone go up and check its condition as the wire in the forestay can become unwound, severely weakening the rig.
In my case the damage was done by the previous owner. I sailed the boat for a couple of seasons like this, unaware there was a problem until I dropped the rig for an inspection. It was NOT a happy day.
This is why you DON'T force things. If something is binding figure out why.
OZWILD and christian.hess like this.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
The Following User Says Thank You to JimMcGee For This Useful Post:
christian.hess (08-19-2014)
post #28 of 30 Old 08-19-2014
OZWILD's Avatar
We had exactly the same issue on our Sadler 25. Being new to furling systems, we had no idea how they were supposed to work, up to the point where we were winching the furling line!
Needless to say, a new headstay, lubricated bearings, cannibalised top cap for the foil and adjusted deflector angle using a strop through the deflector fixed the problem.
christian.hess likes this.
OZWILD is offline
post #29 of 30 Old 08-19-2014
christian.hess's Avatar
on furlers NEVER force anything especially those that arent properly installed or are old and tired...
forestay replacement for furlers, regardless of how well they work should be (to be safe) half that of hank on stays
so figure replace every 5-7 years or so.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #30 of 30 Old 08-21-2014
I had to replace the PO furling line...it was green and moldy and difficult to wrap. I went down in size to the next smaller diameter. As mentioned above, smaller lines can be harder on hands but head up to release some pressure and it works.
1981 Edel 665
Dock C, Lake Front Promenade
i_amcdn is offline
roller furler question Sublime General Discussion (sailing related) 6 05-13-2011 07:35 PM
Roller Furler ID? (w/Pic) Seafire327 Gear & Maintenance 6 05-21-2009 09:28 PM
Roller Furler maintenance JLBJR Gear & Maintenance 3 08-21-2008 03:22 PM
Anyone know how to set up this roller furler somers12 General Discussion (sailing related) 2 05-26-2008 02:52 PM
