Tohatsu troubles - Page 3 - SailNet Community
 7Likes
post #21 of 57 Old 07-09-2013 Thread Starter
Re: Tohatsu troubles
We're going to give it a go at cleaning the carb ourselves this weekend when we're down at the boat. Hopefully giving the carb a good clean will take care of it.
We also found a place to get ethanol-free gas approx. 60 miles from here. Frankly, if that's what's causing the problem we will gladly make that drive with a few 10-gallon portable tanks to stock up!
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #22 of 57 Old 07-09-2013
If you drive that far, and stockpile that much gas, you'll find yourself using very old gas in your motor, which can also cause problems. One advantage to a four stroke is that you can burn off your gas in your truck and never use old fuel for the outboard. Do you really want to take a chance on last year's gas stranding you in the bay?
I'd keep looking for a local source, or better, add a fuel treatment like seafoam.
Smier likes this.
jefuchs is offline
post #23 of 57 Old 07-09-2013
The one problem I had was when I forgot to drain the carb on my Honda 2 HP 4 stroke outboard. The float bowl was full of nasty debris. I have a Honda generator that I replace the fuel once a year. It starts right up on the year old fuel. Did have a small problem with debris or a stuck float but not sure it was because of old fuel, maybe stuff in the tank, it is over 20 years old. I do, however, drain the carbs on my outboards, snow blower and generator. Running them dry leaves a small bit of fuel in the bowl.
I have also used this for many years:
B-12 Chemtool® Carburetor, Fuel System and Injector Cleaner | Berryman Products
FWIW, I bought a new Tohatsu 6HP 4 stroke about 2 years ago. Use it a lot, ran/runs perfectly right out of the box at 6,000 feet elevation, no tweaks or adjustments necessary.
Paul T
dabnis is offline
post #24 of 57 Old 07-09-2013
Puget Sound Pounder
kellysails's Avatar
We always make sure we use Ethanol free gas in our Tohatsu. And we still add fuel treatment to lengthen the life of the fuel. I have the same year but a 6hp version and it has be flawless,,,,,so far.
If possible, don't stock pile gas, even ethanol free goes bad in no time at all. Most all fuel docks have ethanol free gas.
kellysails is offline
post #25 of 57 Old 07-09-2013
chef2sail's Avatar
Our 4 hp Tahatsu has been flawless. Clean gas...like clean diesel is the key
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #26 of 57 Old 07-10-2013
Glad I found Sailnet
Bene505's Avatar
JUst bought a new carb for our 2009 20hp Tohatsu that flipped in Hurricane Sandy. It now runs like new. I figure that will give me plenty of time to clean the old carb, and it was relatively inexpensive (10% of the cost of a new engine).
In prior years, we had a problem that we had to "rev" the engine constantly (like motorcyle riders do, up and down rapidly with the rpms). I'd be curious to hear whether your engine needs "rev-ing". When we replaced the gas the problems went away. remember to drain the bad gas out of the hose too.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #27 of 57 Old 07-10-2013
Bene505's Avatar
I heard that plastic gas tanks deteriorate and clog carbs.
Regards,
Brad
Bene505 is offline
post #28 of 57 Old 07-10-2013
Regards,
Brad
I can only speak from my own experience of having plastic tanks on many motorcycles and outboards for over 40 years. the only fuel related problems I have had were related to forgetting to drain the carb for long periods of time.
There are probably many different types of plastic tanks so it may be a possibility? If they deteriorate you could probably see the debris in the tank or they may start to leak?, which would be very bad, especially with a permanently mounted tank.
Paul T
dabnis is offline
post #29 of 57 Old 07-10-2013
rhr1956's Avatar
Your motor is rated at 1 gallon per hour fuel burn at 5500 rpm. That said you can run at full throttle for about 3 hours on a tank of gas. In reality you will not be running nearly that much gas through it. I wouldn't stock up on a bunch of bulk fuel unless you have some other gasoline sucking equipment to use it in.
rhr1956 is offline
post #30 of 57 Old 07-10-2013
rhr1956 -
We usually run our 8hp Tohatsu with the throttle just cracked open and it quietly pushes our 24' boat along at around 3.5 kt in smooth water. In rougher conditions, we might open it up a bit more. Only when pushing into pretty heavy wind (30+ kt) and sea do we have to open it to maybe half throttle. Do you have any idea what the fuel consumption might be under low throttle conditions?
I've been figuring maybe 1/2 gallon per hour, but haven't been able to find any good information. It would be good to know to get an idea of our motoring range.
polaris2.11 is offline
head troubles...... twisted23 Gear & Maintenance 21 10-14-2010 09:22 AM
Maxsea and USB GPS troubles FollySailor Gear & Maintenance 2 07-08-2010 07:11 AM
overcoming some VHF and GPS troubles CaptainRonandAshley2 General Discussion (sailing related) 1 08-27-2008 04:38 AM
More 12v Troubles and ?'s Perithead Gear & Maintenance 7 11-26-2007 12:33 PM
Starting troubles raybies Gear & Maintenance 4 05-14-2003 08:24 AM
