Tohatsu troubles - Page 4 - SailNet Community
 7Likes
post #31 of 57 Old 07-10-2013
T37Chef's Avatar
Re: Tohatsu troubles
An easy we to determine that would be to track the time (engine hrs) you run the engine and divide that by how much fuel you put back into the tank, do this a few times to get an average and then you should be able to gauge your range.
Shawn
T37Chef is offline
post #32 of 57 Old 07-10-2013
rhr1956's Avatar
Originally Posted by polaris2.11 View Post
rhr1956 -
We usually run our 8hp Tohatsu with the throttle just cracked open and it quietly pushes our 24' boat along at around 3.5 kt in smooth water. In rougher conditions, we might open it up a bit more. Only when pushing into pretty heavy wind (30+ kt) and sea do we have to open it to maybe half throttle. Do you have any idea what the fuel consumption might be under low throttle conditions?
I've been figuring maybe 1/2 gallon per hour, but haven't been able to find any good information. It would be good to know to get an idea of our motoring range.
Not really...I found the info on one of the Tohatsu websites. It showed the 9.8 4 stroke burning 1 gal per hour @5500 rpm. The 6hp 4 stroke burned 0.5 gal per hour at similar rpm. My motor is the 6hp and I have yet to burn a full tank in an entire summer-and we go a couple times a week. Bottom line is...they don't burn much gas.
rhr1956 is offline
post #33 of 57 Old 07-10-2013
rhr1956's Avatar
One more point (been resisting do to not wanting to jinx myself) is that I don't follow any recommendations that I probably should. I don't use a stabilizer, I don't shut off the fuel valve and run it till it dies, I don't run ethanol free gas...hell I don't even winterize it. One thing I do though is run the boat year round, which I think solves a lot of problems. At least a couple times a month throughout winter. If I lived in the cold country I would definately be more pro-active with preventive maintenance. Anyhow...it starts on first pull every time. I love my Nissan / Tohatsu outboard. Geez...I hope I didn't jinx myself.
rhr1956 is offline
post #34 of 57 Old 07-10-2013
Originally Posted by rhr1956 View Post
One more point (been resisting do to not wanting to jinx myself) is that I don't follow any recommendations that I probably should. I don't use a stabilizer, I don't shut off the fuel valve and run it till it dies, I don't run ethanol free gas...hell I don't even winterize it. One thing I do though is run the boat year round, which I think solves a lot of problems. At least a couple times a month throughout winter. If I lived in the cold country I would definitely be more pro-active with preventive maintenance. Anyhow...it starts on first pull every time. I love my Nissan / Tohatsu outboard. Geez...I hope I didn't jinx myself.
Agree, if you use the motor on a regular basis and get good quality fuel and check your filters regularly, you probably won't have any problems. I never used to drain the carb on a number of motorcycles, but I rode all year although not too much in the summer.
As mentioned, the only problem I had was to forget draining the carb on my Honda 2 HP outboard which sat all winter, that one got me. I do use Berryman's fuel additive, which absorbs water, which I understand ethanol fuel absorbs from the air? Not sure if the additive is necessary, but I don't think it hurts anything?
Paul T
dabnis is offline
post #35 of 57 Old 07-10-2013
Glad I found Sailnet
Bene505's Avatar
Originally Posted by dabnis View Post
I can only speak from my own experience of having plastic tanks on many motorcycles and outboards for over 40 years. the only fuel related problems I have had were related to forgetting to drain the carb for long periods of time.
There are probably many different types of plastic tanks so it may be a possibility? If they deteriorate you could probably see the debris in the tank or they may start to leak?, which would be very bad, especially with a permanently mounted tank.
Paul T
I heard that it was more at the microscopic level.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #36 of 57 Old 07-11-2013
Regards,
Brad
Sounds frightening. My Honda pilot SUV has a plastic tank, hope it doesn't blow up my house. Interesting, I will do a search on it later.
Paul T
dabnis is offline
post #37 of 57 Old 07-11-2013
I have a Tohatsu 6HP 4 stroke with an external tank. When disconnecting the fuel line at the tank I get sprayed with fuel which then runs into the bottom of the boat. "open the vent" you say. I did. It appears the vent only vents incoming air to the tank. After the tank sits in the hot sun with the vent open I get a large whoosh when loosening the filler cap. I don't know if there is a pressure limit before it vents "out" or if the tank would eventually burst?. I am going to see if I can retrofit the cap so it will vent in both directions.
End result is that like the portable gas cans sold in California, I spill more gas than I ever did before.
Paul T
dabnis is offline
The Following User Says Thank You to dabnis For This Useful Post:
kellysails (07-11-2013)
post #38 of 57 Old 07-11-2013
Paul T
Do plastic tanks deteriorate?
Ethanol in Gasoline
http://www.goldeagle.com/UserFiles/f...the%20Ugly.pdf
Could be, with ethanol being most of the problem?
Paul T
dabnis is offline
post #39 of 57 Old 07-11-2013
Puget Sound Pounder
kellysails's Avatar
Paul T
I have the same exact setup.
Wow, thanks Paul T, it never occurred to me that the valve was one way. My dink and motor have been sitting in the sun all week. I just sent my wife down to the boat to check the gas tank, damn. I should have thought about that.
kellysails is offline
post #40 of 57 Old 07-11-2013
If you are tired of having gas squirt all over your hands when disconnecting the hose it can easily be fixed. Right in the middle of the cap there is a small rubber "duckbill" valve which allows air in but not out. By removing, just pull it out with a pair of long nose pliers, the tank will then vent in both directions
Not wanting to go to EPA jail, I am not recommending anyone actually do this, but it worked for me.
Paul T
dabnis is offline
head troubles...... twisted23 Gear & Maintenance 21 10-14-2010 09:22 AM
Maxsea and USB GPS troubles FollySailor Gear & Maintenance 2 07-08-2010 07:11 AM
overcoming some VHF and GPS troubles CaptainRonandAshley2 General Discussion (sailing related) 1 08-27-2008 04:38 AM
More 12v Troubles and ?'s Perithead Gear & Maintenance 7 11-26-2007 12:33 PM
Starting troubles raybies Gear & Maintenance 4 05-14-2003 08:24 AM
