Grease on Propeller for Anti Fouling? - Page 3 - SailNet Community
 9Likes
post #21 of 45 Old 12-28-2013
Re: Grease on Propeller for Anti Fouling?
Just thought I would add an update.
It is now 8 months since we applied a lanolin coating to our propeller.
The propeller now has three small barnacles on it but almost no vegetation.
The lanolin is performing much better than the bottom paint we applied at the previous haulout and better for us than when we left it bare.
So here in the PNW it seems to be working.
Regards,
tjvanginkel is offline
post #22 of 45 Old 12-28-2013
no longer reading SailNet
Alex W's Avatar
Well, for a counterpoint I put nothing on my prop last year (I'm also in the PNW). The boat was used pretty often this year (once or twice a week most of the year, about 7 weeks of cruising this summer). I just had the prop changed (fixed to feathering) and the old prop had 2 small barnacles on it. My friend who dove and installed the prop said the shaft had another couple of small ones.
So that is about the same as what your prop.
How much use does your boat get? Could you still feel lanolin on the prop?
Alex W is offline
post #23 of 45 Old 12-29-2013
christian.hess's Avatar
the best antifouling on a prop is USEAGE
use it and be done with it...
Dog Ship likes this.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #24 of 45 Old 12-29-2013
aeventyr60's Avatar
Better still is some thai chili powder mixed with fish sauce. As a binder we use pure 100% virgin olive oil. Rub in well with a scotch brite. This may be illegal in most jurisdictions. Please don't tell the EPA.
christian.hess likes this.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #25 of 45 Old 12-29-2013
Old as Dirt!
svHyLyte's Avatar
An alternative coating that seems have good performance is a product known as (click on) "Prop Glop". Can't hurt. Might really help. Worth a try, eh?
svHyLyte is offline
post #26 of 45 Old 12-29-2013
I,ve used bees wax, applied by melting on to a warmed prop.Frequent use of boat all season helps too.
Capt Len is offline
post #27 of 45 Old 12-29-2013
Max Wax works pretty well in NZ waters-Chris-Tern
White Knight is offline
post #28 of 45 Old 12-29-2013
jppp's Avatar
I wonder if anyone has ever coated a prop with Teflon. Not spray but industrially applied as on frying pan. The barnacles would fling off when prop spins i bet. I always thought that would work on the leading edge of a plane wing as well to avoid icing.
1985 C&C 35 MK 3
jppp is offline
post #29 of 45 Old 12-29-2013
Zanshin's Avatar
Originally Posted by Classic30 View Post
Although not particularly cheap, Propspeed works fine.. just use that and forget about it.
I like the understatement about it not being particularly cheap! I'm preparing my boat for splashing and cleaned the prop and strut and decided to try an antifouling and found Propspeed at the store. It consists of a little plastic baggie with 3 bottles of chemicals and instructions and the price tag was, without reading glasses, US$25.000 which looked rather strange, but with reading glasses that changed to US$250.00! Wow, that is indeed not particularly cheap.
Zanshin is offline
post #30 of 45 Old 12-29-2013
scurvy dog
delan's Avatar
Lanocote works great, if you put your prop in the oven and get it hot, it sucks the lanocote into the pores as it cools. In Miami, the thing I've found works best is a thick black sharpie, again, I warm the prop up until i just handle it, then then use a big black sharpie and black ou the whole prop, it lasts longer than the lanocote.
Restauranteur
Mako 236
Shamrock 26
Schucker 44 Cutter
Dyer Dhow
delan is offline
The Following User Says Thank You to delan For This Useful Post:
christian.hess (12-30-2013)
anti-fouling dubon Gear & Maintenance 2 11-21-2012 08:23 AM
DIY anti fouling Windhorse 166 Gear & Maintenance 3 04-27-2012 02:31 PM
Transducer Anti-Fouling jlmarra Electronics 0 05-13-2011 09:06 AM
Silicon Based Anti-Fouling Ulladh Gear & Maintenance 5 03-09-2011 04:38 PM
Sanding anti-fouling davewild Gear & Maintenance 3 09-09-2009 02:28 PM
