Grease on Propeller for Anti Fouling? - Page 5 - SailNet Community
 9Likes
post #41 of 45 Old 12-30-2013
christian.hess's Avatar
Re: Grease on Propeller for Anti Fouling?
Originally Posted by aeventyr60 View Post
Better still is some thai chili powder mixed with fish sauce. As a binder we use pure 100% virgin olive oil. Rub in well with a scotch brite. This may be illegal in most jurisdictions. Please don't tell the EPA.
chili flakes and cayenne in my antifouling this halout....
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #42 of 45 Old 12-30-2013
I think he is reffering to the color of the strut...some sort of coating?
in any case...guys dont polish your props...really....
do you own an ofrshore racing catamaran with 1500hp worth of outboards? abdsolutely no gain doing that
in effect polsihing a prop melts the top layer of most materials
when people say machine polished or buffed down here especially on magesium, aluminum and some forms of stainless what happens is the top layer gets soo hot that it melts...this closes it all up which is good for stuff like chainplates
mirror polished is what they call it
indeed a rough porous blade is the perfect PRIMER for a simple sprayed on antifouling or nothing at all
again if you have a boat with an inboard and power cruise a lot you will notice less growth than when you only use your inboard to enter ports...
on all the boats I have had with inboards I never did anything to the prop...yes the strut or a arm etc but never the shaft or prop
why? cause you can unbalance a prop quite severely by globbing on antifouling....
youd be surprised how much vibration can come with heavy paint not just barnacles....jejeje
cheers
post #43 of 45 Old 12-30-2013
I don't discuss my member
Fstbttms's Avatar
Originally Posted by outbound View Post
Jon ?what do you have on the strut?
It looks like the Petit Zinc Barnacle Barrier spray.
Fstbttms is offline
post #44 of 45 Old 12-31-2013
I believe you're correct - to be honest, I can't recall, for certain...
I had definitely coated the strut with West epoxy and copper additive as a primer... but I think I had sprayed it with Barnacle Barrier, having also done so to the wire I ran between my keel and rudder...
In any event, I was definitely underwhelmed by the performance of Barnacle Barrier in my home waters :-)
JonEisberg is offline
post #45 of 45 Old 12-31-2013
casey1999's Avatar
I got some of this:
LanoCote Prop & Bottom
Have not gotten a chance to put it on. I got a bad barnacle problem- in 3 weeks prop, strut and shaft are covered.
casey1999 is offline
anti-fouling dubon Gear & Maintenance 2 11-21-2012 08:23 AM
DIY anti fouling Windhorse 166 Gear & Maintenance 3 04-27-2012 02:31 PM
Transducer Anti-Fouling jlmarra Electronics 0 05-13-2011 09:06 AM
Silicon Based Anti-Fouling Ulladh Gear & Maintenance 5 03-09-2011 04:38 PM
Sanding anti-fouling davewild Gear & Maintenance 3 09-09-2009 02:28 PM
