Anyone make new teak pieces on deck - Page 4 - SailNet Community
 26Likes
post #31 of 54 Old 07-15-2013 Thread Starter
Re: Anyone make new teak pieces on deck
Some pics of the wood I am looking to replace. Not sure how you guys post pics on this board. It always fails to upload. Here is a link to my flickr page.
wood to be replaced - a set on Flickr
abrahamx is offline
post #32 of 54 Old 07-15-2013
Seņor Member
PorFin's Avatar
That all looks pretty straight forward, and shouldn't be a major challenge to reproduce.
Here are a couple of other species you might want to research and consider:
- Ipe (pronounced e-pay.)
- Cumaru.
________
'85 BYB Vagabond 39
PorFin is offline
post #33 of 54 Old 07-15-2013
One of None
deniseO30's Avatar
Wow.. that woodwork doesn't even look bad Abraham!
Teak cleaner (oxalic acid) bleach, scrub brushes. sandpaper, 80 to 220 but I'd finished with 150 and it was smooth enough. then a good wipe and soak with acetone and 3-6 coats of finish.
My last project!
deniseO30 is offline
post #34 of 54 Old 07-15-2013 Thread Starter
Its not terrible. In a couple pics you can see where I cleaned the port side. I just used some tide and water. But I have a clorox bleech/tide/tsp mix(as mentioned in This Old Boat) that I am going to use. I have a quarter sheet sander that I believe only goes back and forth and not a true orbital. Will this work fine? I assume so.
abrahamx is offline
post #35 of 54 Old 07-15-2013 Thread Starter
I had not heard of the acatone rinse. Is this necessary? I bought a quart of Cetol that I will most likely use.
abrahamx is offline
post #36 of 54 Old 07-15-2013
Seņor Member
PorFin's Avatar
Yeah, I'm with Denise on this one. Unless the wood has problems we're not seeing (cracks or other failures), then a good cleaning would probably do the trick nicely.
If you decide to go this route, here are a few recommendations:
- Try giving it a good rub down with a white ScotchBrite pad and Barkeeper's Friend cleaner. The B-F cleaner has no abrasive and it's got oxalic acid as a major ingredient. Rinse it well, let it dry and see how it looks.
- If it's still looking a little stained, give a two-part bleach a try (but be careful with it.) Follow the package directions about mixing and neutralizing.
As for finishes, you're sure to get a lot of opinions on everything from leaving it naked to encasing it in many, many layers of varnish.
________
'85 BYB Vagabond 39
PorFin is offline
post #37 of 54 Old 07-15-2013
Seņor Member
PorFin's Avatar
While not strictly necessary, it's highly recommended.
The difficulty with teak is that it's naturally oily, which is one of the things that makes it a great wood for exterior exposed use.
The acetone step removes the oils on the surface of the wood, and promotes a much better adhesion of the finish to the wood.
BTW: Which flavor of Cetol did you get?
________
'85 BYB Vagabond 39
PorFin is offline
post #38 of 54 Old 07-15-2013 Thread Starter
Really the main bad thing is that alot of the bungs and screws are sticking up I assumed cuz of erosion and 40 years of cleaning. I did get the scotchbrite pads and with a laundry soap, bleech, and that tsp or whatever to clean the wood as instructed in "this old boat". I will rinse well and apply the cetol I already purchased. It will be good enough. I'll put my money towards new lifelines. Sooooooo, covered or uncovered in the Great lakes?
abrahamx is offline
post #39 of 54 Old 07-15-2013
Asleep at the wheel
jimgo's Avatar
I had the same reaction. I can see why your father-in-law thought those would be easy to make, but they just need to be refinished. Are you getting leaks from any of the areas where the wood is? If so, you might consider removing all of the wood, refinishing it, and then rebedding it. Rebedding sounds tough, but it really isn't that bad. Here's a great description of the process:
Re-Bedding Deck Hardware Photo Gallery by Compass Marine at pbase.com
Some love Cetol, some hate it. You'll find that that's true of most of the finishes out there. Find what works for you, or what you want to try, and give it a shot. Honestly, most of the finishes will be fine for your purposes, so don't be afraid to go with one. I would, however, suggest putting something on there. The finish helps cut down on damage from freeze/thaw cycles.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #40 of 54 Old 07-15-2013 Thread Starter
I got the marine light. Tastes great, less filling.
abrahamx is offline
Anyone ever try this for a re-make of non-slip deck? souljour2000 Gear & Maintenance 29 12-31-2010 12:15 PM
Suggestion: Make sure you exercise your deck caps... labatt Gear & Maintenance 5 09-08-2009 07:03 PM
Teak pads on deck jhaley66 Gear & Maintenance 6 03-21-2009 08:31 PM
Teak Deck replacement s1j1m10 Gear & Maintenance 8 09-16-2008 05:31 PM
Teak deck Q ekhar Gear & Maintenance 8 03-10-2002 05:48 PM
