Blogs
User Name
Old 03-27-2001
danoc danoc is offline
danoc is on a distinguished road
Removable inner forestay
I remember reading about a product a year or two ago that allowed for the inner forestay to be quickly removed/installed by an attachment on the deck. It had a lever that allowed tensioning/detensioning with a simple, but effective looking locking mechanism.
Does anyone know of such a product and where I can learn more about it?
Thanks
Old 03-27-2001
SHIMSHON SHIMSHON is offline
SHIMSHON is on a distinguished road
Its called a "quick release" and just about all of the major manufactures (ie Ronstan, Schaefer, Lewmar etc.) make them or offer them in their catalogs. Also look at Defenders, Boat US or West Marine.
Old 03-27-2001
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enough
Actually the lever is called a Highfield lever. They are part of quick release system. It is very inportant to install the lever so that the lever swings down and not up when it opens.
There are several other aspects to consider when installing a jibstay or babystay. These stays can pull up in the deck with a lot of force. The above deck point of attachment should be installed in a portion of the deck that has been reinforced for that purpose and below deck there should either be a bulkead or a tesion rod that ties the attachment point from the deck to the hull.
How big a boat are you thinking of doing this on?
Sponsored Ad
Old 03-28-2001
It''s a 32 ft. cutter, and when single-handing it''s difficult to tack the genoa through the slot between the stays. I would be retrofitting the existing fitting. Can''t remember offhand, but I think the stay is 5/16" wire.
Display Modes
vB code is On
Catalina Forestay Woes silverhe Gear & Maintenance 10 06-14-2006 08:11 AM
forestay movement sneuman Gear & Maintenance 1 07-08-2003 04:30 AM
C&C 24 Forestay Broke DanCary Gear & Maintenance 2 01-25-2003 12:52 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
