Motor mount jammed. - SailNet Community
post #1 of 6 Old 07-12-2013 Thread Starter
Motor mount jammed.
I just got our new to us ODay 20 into the water and find I can't get the Garelick motor mount to raise. At least I can use it and I don't want to render it useless by attempting to fix it. My question is: if I take it apart, will I be able to get it back together, are those springs under a lot of tension or it is just a matter of screwing everything back together? Thank you.
marksniat is offline
post #2 of 6 Old 07-12-2013
One of None
deniseO30's Avatar
Re: Motor mount jammed.
spray some silicone or other lube on the joints.
lightly lightly on the engine, pull the handle of the mount down and forward, then if the handle clicks forward, lift slightly on the engine to help the springs.. all this while holding the handle forward pulling up.
hope this helps. http://www.garelick.com/files/12.185.pdf
OPERATING INSTRUCTIONS
To Lower Motor:
Disengage safety lock by pulling it out and
rotating it away from the locknut. Pull lever handle towards the
boat to disengage locking pin. Grasp motor and SLOWLY
lower it to desired height. Release lever handle; locking pin will
snap forward into slot.
To Raise Motor:
Pull lever handle towards the boat to disengage
locking pin. Grasp motor and lift up to desired height. Release
lever handle; locking pin will snap forward into slot. Engage
safety lock by pulling it out and rotating it so it snaps over the
pivot bolt
My last project!
deniseO30 is offline
post #3 of 6 Old 07-12-2013 Thread Starter
Thank you. I have been spraying the mount with Liquid Wrench, but the motor is off when I have been trying to raise the mount. Would the engine in place help?
post #4 of 6 Old 07-12-2013
One of None
deniseO30's Avatar
Oh.. you need weight to disengage it. Motor helps allot. Or a buddy!
My last project!
post #5 of 6 Old 07-12-2013 Thread Starter
I will try in the AM and thank you for the instructions. Mark.
post #6 of 6 Old 07-13-2013 Thread Starter
Did not work, upper bolt seems to be almost welded in place from lack of use. Think a novice can take bolt out or does the springs have to much pressure on them- making it dangerous or impossible to get back together? Thanks again.
Motor mount jammed. marksniat General Discussion (sailing related) 0 07-02-2013 11:42 AM
Bent Motor Mount brrit Gear & Maintenance 1 11-12-2007 09:47 AM
motor mount help hubbardsw Gear & Maintenance 1 11-12-2007 08:07 AM
Motor mount replacement? bread316 Gear & Maintenance 4 11-07-2006 12:17 AM
outboard Motor Mount reid5009 Gear & Maintenance 3 04-12-2003 07:29 PM
