prep and paint - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 07-13-2013
ewe2 is on a distinguished road
prep and paint
Hope someone can help us out.
We are painting our "Sugar & Spice" H40. We have painted and finished many, many projects before, but not a boat. I've been researching, looking at paint reviews and I've come up with a couple of questions. Which is the best paint to use with limited means? She's a beamy gal, and we have to do the best we can at the dock. We can only do a short haul and we wish to do the bottom paint and full inspection when we do. Also can some of the brands be tinted and what tint is to be used? We want a very light green or teal, nothing dark. I'm not seeing these colors at all, except already on the water.
Thanks for the help.
ewe2
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 07-13-2013
SHNOOL's Avatar
I break <-> I fix
SHNOOL is on a distinguished road
Re: prep and paint
Your least expensive paints for topsides (above the waterline, below the deck), are one part epoxies which are basically enamels. Brightside (interlux) is about $35/quart. Their color pallet is pretty good though (but mixing colors gets tricky), check the pallet here:
If you are talking bottom paints... that's a whole other story. Everything there will depend on what you discover when the boat is pulled. Also the type of water you are in most, and whether you have blister issues, or flaking paints.
If I might suggest... if the boat hasn't been painted before, you MAY want to consider wet sanding (600 grit), compounding, polishing and waxing. This assumes your gelcoat is OK.
This was mine before:
This was her after:
"Rum Line" an S2 7.9 - cheap, fast, trailerable, and paid for.
  #3
Old 07-13-2013
deniseO30's Avatar
Oday30!
Re: prep and paint
You don't say, so I'm assuming you want to paint the hull? I consider paint a last resort because paint just doesn't hold up like gelcoat. Is it possible you just don't know how to really restore gelcoat and think painting it will easier?
Denise, Bristol PA, Oday 30. On Tidal Delaware River, Anchor Yacht Club. New Website!
My boat is sold!
  #4
Old 07-13-2013
tommays's Avatar
Re: prep and paint
If you working with limited means THAN the cost of the haul and how long till the next one is a far bigger consideration than the short term cost of the paint
The longest lasting paint which might get you three years ? would work out much cheaper
Do you also want to paint more of the boat than the bottom as your question is confusing ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #5
Old 07-13-2013
Re: prep and paint
Sorry, wasn't trying to be ambiguous. We are painting topside only at this time. She's been through a rough time during Sandy (that's how we got her) and we've been making repairs. Sand and buff is not an option. We're doing the electric from mast to keel, water systems, engine work, repairs on the sails and everything else necessary to make her beautiful aesthetically, mechanically and structurally. We're getting there. Thanks for any help furthering our efforts.
  #6
Old 07-13-2013
pauloman's Avatar
pauloman is on a distinguished road
Re: prep and paint
actually gel coat has a bad reputation - folks with lots of $ will remove the gelcoat on a brand new boat and replace with a two part LPU coating. These are also used on cars and industrial equipment - google lpu.
Actually any outdoor paint or coating will work - from exterior latex house paint (you boat is not much different from the typical beach house) to the high end LPU coatings.
some folks want that flat work boat look, others the mirror image.
epoxy supplier
  #7
Old 07-13-2013
deniseO30's Avatar
Oday30!
Re: prep and paint
Geeze, you have your work cut out for you! You can fix the gelcoat almost like getting it ready for paint. and you would not have the worry of UV damage to paint. Also, for non skid ,Kiwi grip is getting good reviews.
By the way.
CONGRATS ON THE BOAT!
WELCOME TO SAILNET!
AND!
My boat is sold!
  #8
Old 07-13-2013
SHNOOL's Avatar
I break <-> I fix
Re: prep and paint
Yeah, never paint unless you have to, Denise is spot on...
If you can gelcoat it again, all the better.
You were looking for cheap painting alternatives... the one parts are just that, and they don't last, but they look great for a very short time.
  #9
Old 07-13-2013
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Re: prep and paint
One pot paint is easier to apply but does not last as long as a two pot polyurethane like Awlgrip or Interlux Perfection. The prep is the same for both.
Two of three coats a two pot polyurethane will last for 7 to 15 years.
Roll and tip works well and while I have seen it done in the water with the boat heeled over, doing it in the yard is MUCH easier.
White and off white are considerably easier to apply in terms of the finish outcome. Dark blue is one of the most difficult colors to apply and get a good result.
In your position I would favour Interlux Brightside a one pot paint which is easier to apply.
  #10
Old 07-13-2013
tommays's Avatar
Re: prep and paint
Unless your slapping on coat of hose paint there is no way its gonna happen during a short haul
It boggle my mind to even think about doing the topsides on a 40 foot boat as it weeks of work
Tommays
Northport NY
You may post attachments
You may edit your posts
Which First- Paint Deck or prep Teak? Doc_V Gear & Maintenance 2 08-15-2012 12:15 PM
dumb paint prep question moonie5961 Gear & Maintenance 11 04-11-2010 12:21 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Bottom Paint Prep jason3317 Gear & Maintenance 33 03-20-2009 09:45 AM
Which sander for paint prep? theArchitect Gear & Maintenance 9 05-17-2007 10:10 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
