battery isolator with starter/generator? - SailNet Community
Blogs
Old 07-21-2004
owenmccall is on a distinguished road
I am upgrading the shore power battery charging system on my boat from the previous owner''s horrid old automotive type charger to a multistage, two bank marine charger. This boat has a combined starter motor / generator (the starter motor acts as a generator charging the batteries once the engine has started). The PO had the single lead of the automotive charger wired to the "alternator" terminal of a battery isolator. My new charger has separate leads for each of the two batteries. My thinking is to get rid of the battery isolator altogether, wiring the new charger directly to the positive terminals of each battery rather than to the "#1" and "#2" leads of the battery isolator, because I can perceive no function for the isolator on this boat with the combined starter/generator and a two-bank charger. Am I confused? Thanks.
Owen
Old 07-21-2004
jbanta is on a distinguished road
Unless you plan to add more batteries to your bank in the future I can''t see why you would need to keep the isolater in your plan.
Starting Battery vs. House Battery GarrettK Gear & Maintenance 18 10-26-2004 11:58 AM
Battery loses charge svzephyr44 Gear & Maintenance 1 09-28-2004 03:20 PM
Battery Charging Question gwp Gear & Maintenance 6 05-08-2004 12:28 AM
Adding 2nd Battery...help redbeard58 Gear & Maintenance 2 03-03-2003 07:13 PM
Dual Battery Installation Urband Gear & Maintenance 1 03-25-2002 09:57 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
