-   -   Asymmetrical Spi & Foil Headstay (http://www.sailnet.com/forums/gear-maintenance/101383-asymmetrical-spi-foil-headstay.html)
Tansailr 07-15-2013 12:18 PM
We're considering buying a socked asym for our J29 that's sometimes sailed shorthanded. Not having a sprit the tack can fly free or we could mount a tacker on the furled headsail. This latter approach concerns us.....would a puff end up bending the foil? Thoughts would be appreciated! Thanks.
jackdale 07-15-2013 02:02 PM
Re: Asymmetrical Spi & Foil Headstay
This is a contentious issue, right up there with anchors. I am a fan of tackers, I have never had one damage a foil.
capttb 07-15-2013 02:42 PM
I've been hit by 20+ kt gusts with a tacker and the boat has spun out a few times with no apparent damage to a Schaeffer 2100.
SchockT 07-15-2013 06:00 PM
As long as the load is spread out on the forestay a bit, which the commercially available "tacker" type products do, you shouldn't have a problem. Where you might run into a problem is if you just used a piece of rope or webbing, or if you had excessive slack in your headstay.
I'm not a big fan of that setup, but many people do it.
MarkSF 07-15-2013 06:33 PM
So if you have a tacker is the a-sail still gybed outside the forstay, or does it help make it easier to inside gybe?
knuterikt 07-15-2013 07:15 PM
With the asym flying close to or at the headstay your only option is an outside gybe. (assuming that the spinnaker/asym halyard is above the forestay)
The outside gybe is the easiest to do anyhow - just don't let the lazy sheet fall into the water and run over it.
