Drive Train Squeal - SailNet Community
post #1 of 2 Old 07-15-2013 Thread Starter
Drive Train Squeal
I feel like I've been posting too many "what should I do about this?" threads lately, but the feedback has been valuable.
Anyway, when I bought my boat last fall (1981 Spirit 28, Yanmar 2QM15 engine, PSS shaft seal, three blade prop), I noticed that when sailing above about 4 knots, with the transmission in neutral, I could hear a faint squeal (almost sounded like wind whistling over the backstay, but noise went away when transmission was placed into gear, so I knew it was related to shaft rotation). I didn't think much of it, since there was no sound under power, and I could make it stop by putting to the transmission in gear.
But lately, I've noticed that I can hear the same or similar noise under power (in forward gear), as well as under sail (in neutral). The sound is fairly faint -- in fact, it's almost drowned out by the engine noise.
Sound to me like a bearing, but I don't know the exact source. My next plan is to crawl into the engine compartment while underway and have a good listen.
I'm pretty sure it's got the Kanzaki-Hurth transmission. If the noise is coming from there, what are my options?
Any other suggestions?
Rusty123 is online now
post #2 of 2 Old 07-15-2013
Philzy3985's Avatar
Re: Drive Train Squeal
It could be transmission, it could be engine, it could be just a vibration noise of something rubbing in a rhythm.
I have the same thing in fwd gear only, sounds like crickets chirping but only at certain higher RPMs which makes me think "It's just a weird vibration not the transmission" but I'm probably wrong.
Good luck, please fill us in on what you find.
1985 Catalina 30 Std Rig "A Cenoura"
itsACenoura.tumblr.com
Philzy3985 is offline
Drive Train Maintenance PorFin Gear & Maintenance 19 05-07-2012 03:16 PM
How many drive train spares? Jim H Cruising & Liveaboard Forum 8 11-02-2008 11:03 AM
Engine/Drive Train Noise dinkum1 Atomic 4 1 11-29-2006 12:52 AM
Engine/Drive Train Noise dinkum1 Bristol 2 11-18-2006 08:11 PM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 08:00 PM
