horizon clouding face - SailNet Community
post #1 of 2 Old 07-16-2013 Thread Starter
I have an Horizon depth sounder and it has clouded up on the face due to sun exposure when I had to leave my boat in Guatemala and return to the VA in the states for emergency open heart surgery.
The depth sounder appears to be working fine, but I can't read the depth due to a clouding on the face. How can I relieve this problem
sterling stevenson is offline
post #2 of 2 Old 07-16-2013
Old as Dirt!
svHyLyte's Avatar
Re: horizon clouding face
Unfortunately, there is no recovery from black screen death which is caused by UV radiation. Standard Horizon may be able to replace the screen but more likely will advice you to replace the instrument itself. In future, you need to line the inside faces of the covers of cockpit instruments with something like the aluminized reflective tape used by HVAC technicians on AC vents which blocks UV penetration. Short of than a folded pad of aluminum foil will do. The covers alone are not enough, particularly at low latitudes.
FWIW...
svHyLyte is offline
Scratchy compass face chuckg5 Gear & Maintenance 9 09-06-2007 09:34 PM
Which way to face an engine strainer? brak Gear & Maintenance 19 07-25-2007 05:23 AM
Giulietta's face lift !!! Giulietta Gear & Maintenance 50 06-02-2007 07:37 AM
