Cured Sealant Identification and Removal - SailNet Community
 3Likes
post #1 of 16 Old 07-16-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
I removed some of the wood trim from around my companionway on Sunday because I suspect that some of the leakage I'm seeing is coming from that area. I want to rebed everything, especially the screws. When I pulled it up, I noted that the previous owner attempted to solve the leaking problem by applying some kind of sealant to the wood/deck joint. To me, it feels soft and squishy like silicone caulk, and I wouldn't be surprised if that is, in fact, what was used, but I can't be certain. Is there an easy way to identify what was used?
There was also an adhesive/sealant underneath the boards, between the hull and the wood. That stuff seems a little different, but I'm not 100% on that.
If, as I suspect, this is silicone, am I basically stuck wet sanding/wire brushing it out? I saw some information from MaineSail back in 2009 saying that wet sanding was the best bet; I wasn't sure if there was anything new.
Thanks!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #2 of 16 Old 07-16-2013
Re: Cured Sealant Identification and Removal
If you look at this table, you'll see that the best solvents for silicone are toluene, xylene, gasoline, and mineral spirits.
So that suggests that a fine product for removal would be automotive carburettor cleaner spray. I have tried it and it does seem to work well.
MarkSF is offline
post #3 of 16 Old 07-16-2013
One of None
deniseO30's Avatar
I've scraped varnish and goo off the gel coat Jim, it seems to do less damage then sanding which can be done after scraping; unless the scraper gets tilted and makes a gouge? NOPE not me!
Minnewaska and jimgo like this.
My last project!
deniseO30 is offline
post #4 of 16 Old 07-16-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Mark, did you mean to include a link?
Thanks for the info.
wdwright1967 likes this.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #5 of 16 Old 07-16-2013
Oh yes, ooops :
http://www.clearcoproducts.com/pdf/l...olubility1.pdf
MarkSF is offline
post #6 of 16 Old 07-16-2013
Xylene...hmmm..I remember in college I accidentally poured some xylene into a plastic petri dish. Within a couple of minutes the petri dish had dissolved. Not sure what it would do to gelocoat...
paul323 is offline
post #7 of 16 Old 07-16-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
That's my fear about trying many of these things. Seems like they may do more to my gelcoat than just take off the silicone. I keep coming back to the idea of "just" using a wire wheel on a dremel and trying to take VERY light passes. Or just using some wet sandpaper.
I think what I'll do is try GoofOff first (I've read, and the GoofOff site claims) that it can do a good job with silicone on fiberglass. I've already scraped off most of the silicone; I'm now just trying to make sure the oils all get out of the gelcoat. Supposedly the GoofOff will help lift the silicone oils, and then I can just wash the GoofOff off with soap and water.
I still have time to adjust my plans, so any other feedback is appreciated. Otherwise, I'll report back on my success (or failure).
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #8 of 16 Old 07-17-2013
rhr1956's Avatar
Thanks!
GOO Gone Caulk remover! I got it at Lowes and tried it last night. I removed the old silicone sealant used to seal the handrails. I sprayed the stuff on the places and let it sit about 2 minutes. Then scrubbed with a small stainless steel brush. Finally wiped clean with a damp towel. Clean as a whistle now.
rhr1956 is offline
post #9 of 16 Old 07-17-2013
Goo Gone CAULK remover?? I'll have to look for that one.
There was a spray can at Home Depot, I don't recall the name but we just call it "rocket fuel" which did pretty well but not quite 100% on silicones. The mist from it will really eat your flesh though, some of these solvents are real nasty.
hellosailor is offline
post #10 of 16 Old 07-17-2013
rhr1956's Avatar
Yep.. it is.
rhr1956 is offline
Which sealant? copacabana Gear & Maintenance 18 09-27-2010 04:53 PM
Cured ham ... wind_magic General Discussion (sailing related) 9 01-20-2010 04:14 PM
which sealant to use LookingForCruiser Gear & Maintenance 5 07-09-2009 08:18 AM
Cured Resin cleanup problem. FriendsonFire Gear & Maintenance 15 08-07-2007 10:53 PM
What Sealant To Use? 1970Columbia34 Gear & Maintenance 9 11-17-2006 07:44 PM
