Cutlass bearing replacement - Page 2 - SailNet Community
post #11 of 13 Old 08-09-2013 Thread Starter
Re: Cutlass bearing replacement
Caleb
It's 5.5" long, 1.5" shaft by 2" od
Just seeing if anyone had good/bad experiences with a paticular bearing.
Thanks for the link
Mike
Rebuilding The S/V Kompira
SOVT is offline
post #12 of 13 Old 08-10-2013
Tartan 27' owner
CalebD's Avatar
This is the only bearing then that will fit your situation from my link: Johnson Duramax - Cutless Bearings Naval Brass Sleeve: Standard Size, Model Number: BOSS
You might (or might not) have to shave 1/2" off the bearing in my link as it is 6" long - you know, regular size!!!
That link I posted also sells non-brass bearings.
The standard 4" naval brass bearing for a 1" shaft have worked flawlessly for us for just over a year now.
Everybody has one:
CalebD is offline
post #13 of 13 Old 09-08-2013
There are a number of companies that supply composite bearings to what ever size of shaft, carrier and length you require. Just search for composite marine bearings and you'll find one. This is what is typically used in commercial boats these days.
Kutter is offline
Cutlass bearing replacement Norstar Pacific Seacraft 5 02-08-2012 09:55 PM
cutlass bearing replacement 31 orientalnc2010 Pacific Seacraft 19 09-02-2010 01:47 PM
Cutlass bearing replacement... eMKay Gear & Maintenance 7 03-17-2010 09:31 AM
cutlass bearing replacement C-30 jones2ar Catalina 10 03-18-2008 02:24 PM
Cutlass Bearing Replacement, 1985 Najad 343 kc_cmc Gear & Maintenance 2 12-07-2004 02:15 PM
