Heard a squeal and then - SailNet Community
post #1 of 10 Old 07-23-2013 Thread Starter
So I was heading out for a evening sail and about 5 minutes in I heard an incredibly loud squeal, and then I realized that there was no water coming out of the exhaust and the engine was overheating so I ended up turning around and sailing back to the anchorage.
Broke out my copy of this old boat to try and diagnose the problem. It said to check the raw water pump impeller, which I did, and found out that while the piece its attached to is still spinning when the engine is running the impelled is stripped and not spinning with it. That repair looks easy enough and I'm hoping a local boat store here in Vancouver will have a replacement part.
However I'm still nervous about what that squeal was. Is there something else I shouldI check? The engine still seems to run fine. It goes into gear and moves the boat forward and backward same as before. With the cover off the impeller I can feeling the pump is pushing air through at a good rate.
I just feel that the squeal was to loud for such a little piece of rubber. All the vanes are still on the impeller they are starting to seperate though.
Im sure you can all guess what I forgot to double check when I started the engine, hey there is a first time for everything.
Agri is offline
post #2 of 10 Old 07-23-2013
Tartan 27' owner
CalebD's Avatar
Re: Heard a squeal and then
A loud metallic squeal would likely be bearings giving out on a power steering pump or cooling pump or alternator on a car.
I can't imagine an impeller exploding in a raw water pump would make the same sound.
Hopefully it is just the impeller though.
Everybody has one:
CalebD is online now
post #3 of 10 Old 07-23-2013
It may just have been the squeal of the drive belt against the water pump pulley as the pump quit turning momentarily when the impeller failed.
goehner2 is offline
post #4 of 10 Old 07-23-2013
Commodore
n8kraft's Avatar
Squealing on my last boat was improper belt tension to the water pump. I adjusted the tensioning screw and it went away. I later replaced the belt because it started squealing again.
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #5 of 10 Old 07-23-2013
CapnChuck's Avatar
One of our recent additions to the boat is a raw water flow alarm. It's fairly inexpensive and lets us know immediately if the water flow stops, long before the engine starts to overheat. It gives up peace of mind too. The Trawler Beach House: What Works And What Doesn't . Chuck
Our Blogs
CapnChuck is offline
post #6 of 10 Old 07-23-2013
TQA
Bombay Explorer 44
TQA's Avatar
Don't buy one impellor buy 2. Like spare belts an impellor is an essential spare. Keep the tools you needed to change the impellor in a bag with the spare impellor.
TQA is offline
post #7 of 10 Old 07-23-2013
asdf38's Avatar
Right is there a belt driving the water pump? It could have squeeled when it failed. If so I'd go looking for the obstruction that caused the failure.
My pump broke 3 years ago and the busted off impeller blade sat in the system until the next year when it shifted and blocked the system causing overheating. So always look for the obstruction and/or impeller pieces.
asdf38 is offline
post #8 of 10 Old 07-24-2013 Thread Starter
Thanks everyone for all the help and tips. Turns out I had a spare impeller ob the boat, bought a new one as well just in case. Replaced the impeller this after work today and fired up the engine. Everything worked fine. The squeal I heard lasted maybe a second and now that I think about it sounded quite similar to an alternator belt. The belt seems fine though. As for the old impeller there were no missing vanes, a couplebhad started to seperate but that's it. I'm thinking then squeal may have been the brass connector stripping out the inside of the impeller as they came apart.
Thanks again for all the help. I'm definitely going to be looking over the stern more often from now on.
Agri is offline
post #9 of 10 Old 07-24-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
as cheap as Impellers are. I begin to think that replacing them yearly should be a "must do" when getting ready for the sailing season
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #10 of 10 Old 07-24-2013
chucklesR's Avatar
Seriously?
If I kept tools in little baggies, one for each job, I'd have a couple dozen sets of tools scattered around the boat instead of one well organized tool kit.
Okay, actually I have two tool kits, one well organized, one nantucket bucket bag with all the essentials.
Although I will go with a wooden plug on a wire at the through hull I also have a full set in my tool area. I've been through the navy's submarine trainer (USS Dixie Cup) - water flooding in and spraying around makes it darn hard to spot a brown plug in a dark hole/under sole.
I believe it's best to keep everything where you know it is, not where it might be needed.
chucklesR is offline
Drive Train Squeal Rusty123 Gear & Maintenance 1 07-15-2013 02:07 PM
Loss of Tach & Overheat Squeal @ low RPM Blackwater Columbia & Coronado 2 10-28-2010 03:06 PM
squeal from alternator max10 Electrical Systems 10 09-08-2009 05:59 AM
Loud Squeal Melrna Gear & Maintenance 14 07-13-2008 11:55 PM
Anyone ever heard of or used waltzingmatilda Gear & Maintenance 1 08-11-2002 02:27 PM
