Boatlife Lifeseal - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 07-26-2013
snake charmer, cat herder
zeehag's Avatar
Re: Boatlife Lifeseal
works great on my formosa---wish i could find it down here.
formosa 41, cruising tropics
zeehag is offline
post #12 of 12 Old 07-26-2013
bblument's Avatar
Originally Posted by Shinook View Post
... I realized my silly mistake. I tightened all the bolts individually, but failed to go over them again after all six had been tightened. All but one or two were loose, after tightening them I've not observed any leaks on either fitting.
If anyone's seen any of my posts, you already know I'm totally new to all of this, so take this with a grain of salt. However, when you said that you tightened all of the "bolts" that got me thinking. When you use butyl, you should not tighten or rotate the bolts, you should tighten the nuts. Perhaps that's what you meant. When you tighten the bolts, you rotate the threads in the already compressed, sticky butyl and you can create voids and tears. The idea is to compress the butyl in and around the chamfers with direct downward pressure by tightening the nuts on the other side.
If I'm stating the obvious, forgive me... just trying to repay all the help I'VE received here.
Barry
olson34 likes this.
bblument is offline
Boatlife Liquid Life-Calk Sealant-has anyone used it? NauticalFishwife Gear & Maintenance 4 06-12-2013 12:03 PM
Mounting instruments into cabin: screws, and boatlife or epoxy? geary126 Gear & Maintenance 21 02-26-2007 10:50 AM
3m 4200 or Boatlife RobGallagher Gear & Maintenance 1 04-11-2003 06:47 AM
