Flying a Symmetrical Like an Asymmetrical - Page 3 - SailNet Community
 1Likes
post #21 of 26 Old 07-26-2013
Old as Dirt!
svHyLyte's Avatar
Re: Flying a Symmetrical Like an Asymmetrical
Originally Posted by SHNOOL View Post
If I might, he has a hank on jib, the TAN might get trashed sliding up and down a bare forestay...
I presume you meant "ATN" above (as in an ATN Tacker) and you are exactly correct. With naught but a bare headstay, the parrel beads are replaced with a short length of double layered of webbing, sewed together, with grommets on each end.
svHyLyte is offline
post #22 of 26 Old 07-26-2013
ASA and PSIA Instructor
Originally Posted by 5hortBu5 View Post
...I've no idea what that loop is there for.
The loop is termed a spinnaker crane.
sailingfool is offline
post #23 of 26 Old 07-26-2013 Thread Starter
5hortBu5's Avatar
Well, that just smashes any doubt now, doesn't it? Additional halyard, it is!
5hortBu5 is offline
post #24 of 26 Old 07-26-2013
Originally Posted by MastUndSchotbruch View Post
Glad it worked for you.
But why not just fly it as a symmetrical spi, just without the boom? Even though I have a spi boom with all its paraphernalia, I do this some times to avoid the complexity of the boom. You won't be pointing very high but if you are running or on a broad reach, it will sure speed you up!
Flying this setup off the wind without a pole will reduce the power of the spinnaker by some big factor, say 50-70%. Better than than none, yes, but not at all what the sail can offer.
post #25 of 26 Old 07-27-2013
Senior Moment Member
SloopJonB's Avatar
I've flown a Sym. chute on a Hunter 38 with no pole. We rigged up a strop (length of line with an eye splice at each end) around the anchor roller with the jaw of a large snap shackle pinning the ends of the strop into a longish loop (3'?). The tack of the chute was held by the snap shackle. We used sheets twice the length of the boat so we could gybe the chute by streaming it ahead of the headstay and turning it inside out.
It worked pretty well and cost next to nothing - $400 for a decent used chute, $200 for the lines and shackles.
Easy to fly and lots of fun for small $$. We could get surprisingly high with the rig but couldn't sail very deep because of the big main on the Hunter.
The friend who owns the boat said he's seen 10 knots on the speedo flying it like that in a breeze.
SloopJonB is offline
post #26 of 26 Old 07-27-2013
Yeah, probably, at least once you are off the wind.
However: (a) In the light winds I am using the spi (I usually single-hand and am pretty conservative, so no gale-force spinakering for me), the spi brings the boat up to pretty much the speed of the wind. If it had 10 times more power, it would STILL be the speed of the wind
And (b), the OP specifically asked for a possibility to use his spi without a boom.
MastUndSchotbruch is offline
Asymmetrical vs symmetrical spinnakers jarcher Racing 10 05-06-2009 09:36 PM
Symmetrical Spinnaker recut to Asymm newpbs Gear & Maintenance 2 08-19-2008 11:00 PM
Cruising Spinnakers (Symmetrical or Asymmetrical) couzensj Learning to Sail 2 06-24-2003 07:00 PM
asymmetrical or UPS ? henryvand Gear & Maintenance 0 10-18-2001 04:52 PM
Asymmetrical vs. Symmetrical Spinnakers Dobbs Davis Racing Articles 0 11-15-2000 07:00 PM
