SF Bay - how long do you get out of Pettit Trinidad SR? - Page 4 - SailNet Community
post #31 of 39 Old 07-29-2013
STARBOARD!!
KeelHaulin's Avatar
Re: SF Bay - how long do you get out of Pettit Trinidad SR?
That picture was taken before pressure washing. It was about 3 months after the bottom was cleaned. There is a bit of hard growth on the lower edge of the keel but that's why the diver said it was getting close to being time for a haulout. After it was washed it was pretty much clean aside from the little bit of hard growth at the lower edge of the keel. As I said before; I'm not really concerned about how much slime growth there is on it; most all bottom paints will allow slime growth despite the additives that claim to prevent it.
KeelHaulin is offline
post #32 of 39 Old 07-30-2013
I don't discuss my member
Fstbttms's Avatar
3 months of fouling on a 5 1/2 year old bottom and there is almost no discernable growth? Look at the running gear- clean as a whistle. The waterline? Spotless. Sorry and I absolutely mean no offense, but I ain't buying it. It doesn't add up. If that's what the boat looked like fresh out of the water after not having having been touched for three months, why bother painting it?
I suspect that you are mistaken about the boat not having been pressure washed in this pic.
Fstbttms is offline
post #33 of 39 Old 07-30-2013
STARBOARD!!
KeelHaulin's Avatar
As I said before; the prop and shaft was painted with Ultra also. There were barnacles where it had washed away. The waterline on the port side is clean because the boat does not sit perfectly level when in the slip. I was having trouble with hard growth on the starboard boot stripe because it was submerged. I fixed that problem by painting the lower stripe with Pettit Vivid to match the hull. Since the diver said it was becoming difficult; and knowing how long it had been I assumed it would be worse than it was. But going on the hard is not really optional once it's out of the water.
Nope; that was before pressure washing. I would not post these pictures or make a false claim about something like this if it were not true. Some people get 3 years and then haul regardless of bottom condition. Since the diver had not said it needed a haulout I let it wait until he suggested it was time. Here are a couple more pictures.
Being hauled hanging over the water:
Message - My Photo Gallery
Being pressure washed:
post #34 of 39 Old 07-30-2013
Fstbttms's Avatar
I don't maintain that you aren't telling what you believe to be the truth, I'm simply saying that what you are claiming is outside my personal experience. The pic you posted is of a boat that essentially doesn't even need to be cleaned. A 5+ year old bottom in the central Bay that hasn't been touched in three months that is virtually spotless? Again, completely outside my experience.
I'll ask again- if the paint is working that well, why repaint?
Fstbttms is offline
post #35 of 39 Old 07-30-2013
STARBOARD!!
KeelHaulin's Avatar
So knowing that it's 5.5 years old; knowing that the bottom paint is getting difficult to scrub per what the diver is saying, and the boat already in the slings with an agreement that the yard that they will sand and paint the hull, I'm supposed to say 'oops, put me back in the water' instead? In addition I had already bought new depth/speed instruments, dripless shaft seal, drivesaver, and feathering prop. Can't install them without going on the hard...
post #36 of 39 Old 07-30-2013
Fstbttms's Avatar
Hadn't seen the additional pix until now. Is your paint blue?
Fstbttms is offline
post #37 of 39 Old 07-30-2013
STARBOARD!!
KeelHaulin's Avatar
Yes, blue paint; it becomes lighter blue over time. When first painted on it's nearly as dark as the boot stripe.
post #38 of 39 Old 07-31-2013
Senior Slacker
SlowButSteady's Avatar
I have Trinidad on my boat (in Southern CA; King Harbor/Redondo Beach). It's been almost exactly four years, but it's just about due. I'll probably haul it and repaint the bottom this Fall.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #39 of 39 Old 08-01-2013 Thread Starter
Well thanks for the input everyone, this has been a far more interesting discussion than I anticipated when I started the thread
MarkSF is offline
Pettit Vivid compatibility Minnewaska Gear & Maintenance 0 08-30-2010 06:43 PM
Pettit Easypoxy Sandtone SuzySailor Gear & Maintenance 3 11-16-2007 01:13 PM
Pettit Vivid Lecy Gear & Maintenance 0 03-20-2007 02:04 PM
Pettit Vivid ThunderFog Gear & Maintenance 2 09-30-2006 07:27 PM
pettit trinidad ttmama Gear & Maintenance 1 06-11-2001 03:24 PM
