What sort of valve is this? - SailNet Community
 2Likes
post #1 of 18 Old 07-25-2013 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
My galley sink has this:
Ignoring the general ugliness of it, what kind of valve is it? The handle only moves fore/aft through about 80 degrees, but when I had her out on the hard, the valve seemed to function just fine. Surveyor notes mentioned that it was a gate valve and it was seized, I don't think it's a gate and it's definitely not seized.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #2 of 18 Old 07-25-2013
Re: What sort of valve is this?
I have never seen anything like it. It looks like a gear driven gate valve.
The hoses look old enough to replace, and my curiosity says when you have it on the hard next replace the hose and clean polish and lube the valve. I would take it apart in little pieces to see how it works. Might have to replace it afterwords though.
desert rat is offline
post #3 of 18 Old 07-25-2013
Come on this is easy
Sent from my MID using Tapatalk 2
tom_beckstedt is offline
post #4 of 18 Old 07-25-2013 Thread Starter
Clearly not that easy, or I'd know the answer, or be able to easily find it using Google
Care to share?
Orange Crush
1974 C&C27 MkII
post #5 of 18 Old 07-25-2013
Open it drains closed it don't that is all that matters looks like mine why do you need to know the name of the valve it self?
post #6 of 18 Old 07-25-2013
It is a type of gate valve. The lever moves the gate into the area under the hex nut cap thing to open it.
You say that the handle has limited travel. That's probably a good sign.
If the gate was frozen and the stem broken, I'd expect the handle to move until it was stopped by the hose.
I'd just pull the hose and see if you can control the water with the valve. If you can't, put the hose back on and arrange to put in a real seacock soon.
hopcar is offline
post #7 of 18 Old 07-25-2013
rugosa's Avatar
Predecessor to today's gate valves, simple lever action, easy to see/feel if open/closed, quality product in it's day - likely old Apollo, Groco, Buck-Algonquin, but no longer in their catalogs
rugosa is offline
post #8 of 18 Old 07-25-2013 Thread Starter
OK, thanks.
Orange Crush
1974 C&C27 MkII
post #9 of 18 Old 07-25-2013
fryewe's Avatar
If it is your galley sink drain hull valve and the sink drains and it is seized...it is seized open and that gives a bit more urgency to fixing it.
Also if there is a chance it is seized obviously you don't want to pull the hose (or pull the side plug on the valve) to look at its inner workings.
If you aren't going to be on the hard for a while and it is convenient to plug the hull connection from outboard in order to remove the hose or side plug to have a look you might want to do that.
The side plug is probably there to allow cleaning and servicing.
If it is a gate valve and is designed to be operated by a quarter turn throw of the handle then either it doesn't open very far or there may be a gear inside the valve body to amplify the throw. And if it's not designed for a quarter turn throw it is likely broken and seized.
I'd be interested in knowing what you find out.
Good luck.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #10 of 18 Old 07-25-2013
Here is a drawing that shows how it works.
http://www.matco-norca.com/images/pr...Spec_Sheet.pdf
fryewe and rugosa like this.
hopcar is offline
Anyone know what sort of boat this is ? Samboo General Discussion (sailing related) 4 08-15-2011 12:50 PM
Sort of looks like self tailer EpicAdventure Gear & Maintenance 6 07-06-2010 08:16 PM
Replacing SeaCock Gate Valve with Marine Ball Valve saurav16 Gear & Maintenance 30 06-15-2007 10:52 PM
