White powder around stuffing box. - SailNet Community
post #1 of 12 Old 07-26-2013 Thread Starter
L124C's Avatar
Just discovered this ring of white powder around the stuffing box. Never noticed it before. Very fine, I'm guessing salt (I didn't taste it).
Shots are not great, but should give you the picture.
Thoughts?
L124C is offline
post #2 of 12 Old 07-26-2013
weinie's Avatar
Re: White powder around stuffing box.
how are your zincs?
weinie is offline
post #3 of 12 Old 07-27-2013 Thread Starter
L124C's Avatar
Originally Posted by weinie View Post
how are your zincs?
Zincs were fine a month ago. What would the powder be if they were not?
Going to fire it up today and make sure the adjustment is correct. Hope it's not generating too much heat.
L124C is offline
post #4 of 12 Old 07-27-2013
Tartan 27' owner
CalebD's Avatar
I think Weinie is thinking electrolysis, like you get powder buildup sometimes on your battery terminals on a car.
I'd guess that salt is fairly likely, unless your boat is in the Great Lakes.
With the fancy Gore GFO and GTU packings I've noticed a dark gray liquid spinning off my shaft right at the stuffing box where the drip comes out. What is a little weird is that your ring of white powder is between the stuffing box and shaft log hose and not where the shaft enters the stuffing box. Where your white ring is there should be no water getting out from the two hose clamps.
I'm going to guess that your white ring is some compound that was applied (long ago) which has now turned into a powder. Perhaps a white lithium grease? used to make it easier to fit the hose over the stuffing box hose barb.
If this is the case then I don't think it is anything to worry about.
Everybody has one:
CalebD is offline
post #5 of 12 Old 07-27-2013
I don't discuss my member
Fstbttms's Avatar
Originally Posted by CalebD View Post
...electrolysis, like you get powder buildup sometimes on your battery terminals on a car.
Bingo.
Fstbttms is offline
post #6 of 12 Old 07-27-2013
CaptainForce's Avatar
'just to gain a little more knowledge, you can collect a sample of the white powder on a shallow glass and place a drop of water on the power, then stir with a toothpick. If it's a salt, then it will quickly dissolve.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #7 of 12 Old 07-28-2013
Asleep at the wheel
jimgo's Avatar
Perhaps someone is attempting to smuggle substances aboard your boat when you aren't there?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #8 of 12 Old 08-03-2013 Thread Starter
L124C's Avatar
As a result of this thread Pink metal on stuffing box, I bonded the stuffing box to DC ground about a year ago. Wonder if there might be a connection?
L124C is offline
post #9 of 12 Old 08-03-2013 Thread Starter
L124C's Avatar
Or maybe the boats producing it! A pleasure boat that MAKES money...now that's a first!
I wish!
L124C is offline
post #10 of 12 Old 08-09-2013 Thread Starter
L124C's Avatar
Just checked the stuffing box. No powder so far I'll keep an eye on it.
L124C is offline
Powder Coating for Cleats? Hudsonian Gear & Maintenance 7 04-08-2012 12:51 AM
Powder Coating for Cleats? Hudsonian Gear & Maintenance 1 04-07-2012 03:14 PM
prp soy powder jasonr575 Gear & Maintenance 1 03-05-2010 03:24 PM
epoxy and copper powder on your propellor groundhog Gear & Maintenance 21 06-14-2009 02:15 PM
Powder Coat on board? meuritt Gear & Maintenance 10 01-15-2009 03:20 PM
