Old 08-02-2004
ikent is on a distinguished road
Engine mounts vs isolators
We are replacing our engine mounts and a mechanic said to go with engine isolators instead of regular mounts. Does anyone here know much abou the difference? I appreciate any insight you all can provide.
Thanks
Ike
Old 08-03-2004
VIEXILE is on a distinguished road
I just put in isolators and think next time I''d stick with the old adjustable mounts. If you''re bolting to a fiberglass/wood bed, what''s the difference? A drivesaver will isolate the shaft from the water. The Globe mounts I put in are plastic with the only available adjustment being the plastic shims, purchased separately. Out of four mounts, I only needed one shim. Honestly, I don''t see a huge reduction in vibration. Do you have steel beds or a steel hull or something?
Old 08-03-2004
We''re not steel, it was just a recommendation from a mechanic. The old mounts broke after we wrapped a line so we have to do the work anyway. I was just wondering what the thinking was out there. Engine is on wood on F/G stringers.
Thanks for the note of experience.
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 05:14 PM
Broken engine mounts lgsailor19 Gear & Maintenance 3 06-03-2004 12:46 PM
Corroding Engine Mounts ccannan Gear & Maintenance 0 08-08-2003 01:56 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 11:31 AM
