Adhesive for Rub Rail - SailNet Community
post #1 of 3 Old 07-27-2013 Thread Starter
Just had the boat painted and now need to replace the hollow, stainless steel rub rail. Questions: Should adhesive be applied to just the screws or the entire underside of the rail or just a small bead along the edges? What is the best sealant to use? Any preparations to the newly painted (Awlgrip) surface prior to attaching? How best to clean off any excess? Any advise would be most helpful and appreciated.
D Schuller is offline
post #2 of 3 Old 07-27-2013
Adhesive to the screws is adequate. The screws should be close enough together to provide a tight fit. The adhesive acts as a sealant where the screws penetrate the hull.
talyn1 is offline
post #3 of 3 Old 07-28-2013
72 C&C Corvette
CorvetteGuy's Avatar
Re: Adhesive for Rub Rail
Many posts on bedding hardware, Bytle tape being the most common
CorvetteGuy is offline
Adhesive Question sct5566 Gear & Maintenance 10 06-28-2012 12:04 AM
adhesive for Hypopolymer kotuku Gear & Maintenance 3 04-16-2011 02:25 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
PVC Adhesive equitiman Gear & Maintenance 2 05-15-2007 03:24 AM
Adhesive for deck superdave Gear & Maintenance 5 03-30-2007 10:19 PM
