How are lifeline stanchons mounted? - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 07-29-2013
chef2sail's Avatar
Re: How are lifeline stanchons mounted?
The stanchion holder has a slot in it which fits over the toe rail, It is then bolted to the toe rail and then the deck. Our toe rails are bolted onto the hull deck joint with 4 inch centers, all great strength vs a stanchion base embedded in the gelcoat and bolted through it.
If the stanchion gets struck or wears over time it wobbles in the base vs eventually weaking the gel coat and causing leaks like many stanchions.
You have to have the proper toe rails of course, but this design is a pretty good one. As was stated you it also gives you more room on the gunwhales. The disadvantage is they are more outboard and you must be careful of pilings when docking.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #12 of 19 Old 07-29-2013
Senior Moment Member
SloopJonB's Avatar
Unless I'm mistaken, with those rail mounts, the bolt that goes through the deck utilizes one of the existing holey rail bolt holes as well, so no extra drilling.
SloopJonB is offline
post #13 of 19 Old 07-29-2013
chef2sail's Avatar
On the C&C ones, there are two on the base which re 4" apart and can utilize the exciting toe rail bolts. Not all toe rils have 4" apart though. Additionally there is a horizontal bolt through the stanchion base which after it is put over the toerail slot holds the base to the toerail.
South Shore Yachts | Certified Yacht Broker, C&C Parts and Service » Type C Base
Parkville, Maryland
Our blog-
post #14 of 19 Old 07-31-2013 Thread Starter
How the hell does one bed a screw when you can not hold it steady while putting on the nut?
abrahamx is offline
post #15 of 19 Old 07-31-2013
SloopJonB's Avatar
That's what crew or helpers are for - they hold the other end steady.
post #16 of 19 Old 07-31-2013 Thread Starter
Well in my case there is no other end. Just screws going through aluminum that is sandwiched inbetween the glass. No bolts or nuts. Maybe a bolt but no nut.
abrahamx is offline
post #17 of 19 Old 07-31-2013
SloopJonB's Avatar
In that situation the screw carries some of the bedding with it as it is screwed in - just make sure you start with lots.
post #18 of 19 Old 07-31-2013 Thread Starter
Yep
abrahamx is offline
post #19 of 19 Old 08-01-2013
Strait Shooter's Avatar
I need to make one more post so I can see images.
I need to see toe rail attachments.
Strait Shooter is offline
I need some lifeline help abrahamx Gear & Maintenance 10 07-26-2013 01:12 PM
Lifeline Batteries clarity36 Electrical Systems 27 06-03-2012 11:05 PM
Lifeline Maintenance MikeinLA Gear & Maintenance 1 05-07-2012 01:56 AM
Deck mounted versus keel mounted masts VetMike Gear & Maintenance 35 02-17-2012 09:59 AM
Lifeline netting... scurvy Seamanship & Navigation 17 07-20-2007 08:01 AM
