Blogs
User Name
Old 08-03-2004
Armchairprotest Armchairprotest is offline
Armchairprotest is on a distinguished road
Carbon Rudder Post
I own a ''77 Newport 30''. Absolutely love it. Two weeks ago the rudder post began to slip in the rudder. I found over the years that the straps welded to the post that are held in place by the foam core finally sheared off from corrosion. And now the post just turns.
So I''ve done a bunch of research and decided to redisign the post (Very poor original design) and I''m very happy with the new look I''m going for. (For those of you interested, I''m using the NACA0012 airfoil design).
Here''s the beauty, I wanted to use Carbon Fiber (CF) instead of the same old Stainless post so I never have to worry about corrosion again. I found a company that has 4 tubes that are the exact Outside Diameter (1.8785 - 1 7/8) whose modulus strengths and torsional strengths are very close to the old SS post.
Now I''m mostly a bay and coastal cruiser so I''m not going to worry about having a post that can withstand typhoon weather. The two composit engineers I''ve spoken with fully believe that the CF replacement will be more than adequate.
So, anyone want a Carbon Fiber post O.D. 1 7/8" by 60". The guy is asking $125 per piece.
vB code is On
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 02:11 PM
Building a New Ruuder Armchairprotest Gear & Maintenance 15 10-26-2006 03:59 PM
Is my rudder OK? raybies Gear & Maintenance 1 01-07-2004 02:33 PM
Rudder Post Problem nauticalrich Gear & Maintenance 3 04-08-2003 07:13 PM
cracked rudder aasault Gear & Maintenance 0 10-10-2001 04:30 PM
Page generated in 0.3287 seconds (45.74% PHP - 54.26% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
