transom ladder installation - SailNet Community
Blogs
Old 08-03-2004
alibi is on a distinguished road
Im about to mount a transom ladder. Is it best to install some wood block so I can drill thru the transom and wood and bolt the ladder on? Thanks for any advice
Old 08-04-2004
paulk's Avatar
paulk is on a distinguished road
Putting in a backing block is probably a good idea to spread out the load. You can use wood, but might also want to consider a metal plate. (Wood may be crushed by the bolts, and can also rot, later on. ) Be sure to use plenty of bedding compound/silicone goop to keep the water OUT of the joint.
Old 08-05-2004
GordMay is on a distinguished road
YES
You need a backing plate; and (as Paulk says) Aluminum would be better than sealed wood backer.
Don’t forget to seal the transom mounting hole edges (epoxy), then bed the bolts & ladder mounting plate.
If your transom is cored, you should back-cut & remove the coring and in-fill with thickened epoxy (for crush-resistance, etc).
Regards,
Gord
Old 08-05-2004
YES
Drill the bolt-holes perpendicular to the mounting surface.
Regards,
Gord
Old 08-06-2004
Thanks alot for the advice and metal plate seems like a good idea.
RIBs with Fold Down Transom timl Gear & Maintenance 7 09-17-2008 10:22 AM
Yanmar installation manual prussell Gear & Maintenance 9 12-14-2007 05:53 PM
Ladder question mcain Gear & Maintenance 14 08-03-2007 11:28 PM
Ideal boarding ladder dscottl Gear & Maintenance 7 07-02-2002 06:25 AM
transom ladders trcal Gear & Maintenance 0 12-15-2000 11:54 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
