Remove the lettering with Easy Off Oven Cleaner.
If the paint has been on a long time, you may see a shadow of the old name .... will eventually fade in sunlight.
This oven cleaner nonsense is an urban legend, I''ve tried it and it pales in comparison to "Fibreglass paint remover" tada! Read the label, follow the directions and voila, no name! I would use the high quality vinyl (peel and stick) for the new name.
A couple of things.... First off, I watched a guy use oven cleaner on the painted name on his fiberglass boat. It was messy and a lot of work, however, work it did!!! I would try the fiberglass paint remover first. Also for the new name, I would use vinel stick ons made by a sign shop that does not necessarly deal with boat names. My boat name with a contrasting boarder, my hailing port in fancy letters and my bow numbers all cost under $60. They have been on for two years and still look great. If they fall of tommarow, I will consider it money well spent and do the same thing all over again.
Good Luck and happy sailing
I used Easy Off about a month ago to remove the painted on name on my 1986 Newport.
The Easy Off worked very well. Be sure to wear gloves and a goggle when you do it. Just spray a generous amount on the painted on name, then wait 10 minutes. Use some rags or a sponge and the paint will melt right off. It did not hurt the gelcoat at all.
Good luck,
Barry
Related Threads
1.7M posts
173.8K members
Since 1990
