Do I have to predrill before running screws into fiberglass - Page 3 - SailNet Community
 9Likes
post #21 of 24 Old 08-01-2013
Asleep at the wheel
jimgo's Avatar
Re: Do I have to predrill before running screws into fiberglass
Something like these should do the trick:
3-In-1 Hex Bit Countersink Tool
Countersink and Deburring Tool Set
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #22 of 24 Old 08-02-2013
If you are trying to use a larger drill bit as your chamfer tool you may end up with a bigger hole. Most drill bits are made to pull in so when you try to just "kiss the edge the drill pulls itself in. Sometime running a larger bit in reverse works but I learned the hard way that on fiberglass/gelcoat a chamfer bit is the only way to go.
my 2 cents
John
abrahamx likes this.
jfdubu is offline
post #23 of 24 Old 08-05-2013
What if you are replacing wood. Is it recommended to re-use the original screw holes (any preparation required?)? Or should I fill the holes and drill new ones?
rndmtrvlr is offline
post #24 of 24 Old 08-06-2013 Thread Starter
I'm not done yet but I am filling the old ones and drilling new ones. I'll reuse the through hole winch holes. I filled all my handrail holes. I did not take them off myself and after reading "this old boat" it says hand rails must be through hole bolts. I'm not sure if mine were or not. If they were I probably would have reused the holes although this old boat says to make new ones.
abrahamx is offline
Epoxy screws davidpm Gear & Maintenance 7 06-22-2013 12:44 AM
How Do you Organize screws? SaltyGirl Gear & Maintenance 19 08-25-2009 02:31 AM
Screws into fiberglass floatsome Gear & Maintenance 6 04-29-2009 08:14 PM
Loose screws bmcald Gear & Maintenance 13 05-29-2002 11:57 AM
