longer hitch for launching boat - Page 2 - SailNet Community
post #11 of 16 Old 08-08-2013
4KSB driver.
SHNOOL's Avatar
Re: longer hitch for launching boat
I think the extension will work fine by the way...
I know the tongue weight on my 25 footer (lighter than yours) pushes 500lbs. But when you combine THAT with the angle of launch, and the tongue weight actually decreases dramatically. I WILL strongly suggest you not hitch to the extension until you are ON the ramp though. Block the trailer, unhitch, slide in the extension, hitch, pull forward, unblock, then slide it in!
Make sure to remove the extension as well on the ramp... And you'll be able to use that thing for years!
I had a sliding neck on my old trailer, I think the stress is manageable.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #12 of 16 Old 08-09-2013
blt2ski's Avatar
We had a trailer with a built in 10' extension so we could float the 21' CB boat I grew up sailing as a teen. Pretty common way to make it easier to get a boat in and out of the water.
I do agree that a hitch extension is not the best option, extending the trailer tongue is the "BEST" option, but for a short 100'/yd trip typically at best, with speeds under 5-10 mph, should not be an issue!
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #13 of 16 Old 08-12-2013
Yes, I agree, my trailer rolls less than 80 feet each way with the extension connected. Probably never sees speeds over 1/2 mph. I do get a lot of looks from other boaters launching though. I recommend anyone planning a deep launch to do some research on how far the concrete extends down the ramp to avoid the dreaded drop off and possible wheel hang up on the trailer retrieval. I would not trust a verbal description from anyone unless i see them launch a boat/trailer combo similar to my setup. If there is a pier next to the ramp you can use a piece of metal emt conduit and tap on concrete ramp as you walk out to deeper water while still on the pier. When the clank sound changes to a thud, you are in sand/mud and past the lip of the ramp. Make a note of how far out you walked and also what the tide status is at that time of the day. This worked great for me as i launched from a strange ramp for the 1st time with zero surprises.
Bruce_L is offline
post #14 of 16 Old 08-13-2013
4KSB driver.
SHNOOL's Avatar
To answer the question of "why such heavy tongue weights?"
Easy... tongue weight should be 10% or MORE of the weight of the all-up package of boat and trailer.
I'm at #2950 for the boat, probably #1000 for the trailer (minimum), without any extra gear. So Figure #3950... 10% is 395lbs, and the tongue is every bit of that, if not slightly more. THAT'S why such heavy tongue weight! if you are less than 10% tongue weight, you have a serious unbalanced rig and should consider moving the boat forward on the trailer.
SHNOOL is offline
post #15 of 16 Old 08-13-2013
hey, man, if it works for you, go fo it...
Mine is almost exactly the opposite... one guy already posted the idea, but i LOVE my trailer's extention. the "trailer hitch" is on a 10-ft long 3x4 rectangular tube that slides into the main "beam" of the trailer and is "pinned" with a 3/4" pin. When it is fully extended, it lengthens my trailer by about 10 ft. Of course, you can't tow with it that way, but man it is easy to put the boat in and out of the water. Sometimes my tires don't even get wet!
A creative guy with a torch and a welding rod coould do the same for YOUR trailer...
Johnnycatt is offline
post #16 of 16 Old 08-14-2013
Turn your spare wheel into a fifth wheel and launch with a strap
Spare Tire Carrier And Spare Hub 1-3/8"- 86079 | Trailer Spare Tire Carriers And Mounts | Tie Down Eng | TrailerPartsDepot.com
oomfh is offline
Tags
hitch , oday 25
Launching the boat davidpm General Discussion (sailing related) 4 06-03-2013 05:27 PM
Wich boat for a longer trip patroeski Boat Review and Purchase Forum 0 10-10-2012 08:22 AM
How much longer (or shorter) is your next boat going to be? Bene505 General Discussion (sailing related) 108 02-21-2012 11:59 AM
My Wife is no longer allowed on our boat,.... DrB General Discussion (sailing related) 19 09-23-2008 01:08 PM
Using a Cow Hitch Eric Watters Seamanship Articles 0 02-06-2002 07:00 PM
