Rudder repair, how would you? - SailNet Community
 1Likes
  • 1 Post By sony2000
post #1 of 7 Old 08-02-2013 Thread Starter
So we purchased a 12' sailboat (1975 Jester 12) for the grandkids to putter around in and "crunch" off comes the top of the rudder. It's 3/4" thick - so I am thinking I'll just recreate the whole top portion with Starboard.
What do you think?
oomfh is offline
post #2 of 7 Old 08-02-2013
Re: Rudder repair, how would you?
I'm happy to see the top is off, not the bottom. The repair is relative easy.
sony2000 is offline
post #3 of 7 Old 08-02-2013
Over Hill Sailing Club
smurphny's Avatar
Could you just round it over, glass over the top and put the tiller back on. It looks like it might be high enough so the tiller will clear. If you overlapped it down 6" or so with a couple of layers of heavy cloth, it would strengthen it as well. I'd worry about where it was going to break next. Why not just make a new one out of a good piece of 3/4" marine plywood?
smurphny is offline
post #4 of 7 Old 08-02-2013
SchockT's Avatar
That's pretty easy since it is not part of the actual foil so shape doesn't matter, just copy the broken piece in whatever material you are comfortable working with. Something buoyant might not be a bad idea in case the rudder comes off in a capsize, although with that big hunk of stainless it will probably sink anyway!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #5 of 7 Old 08-02-2013
The core is a foam form. I suggest digging it out lower than the fiberglass covering, epoxy in a plywood to replace the lost core, and cover it with fiberglass material. Then paint with white gelcoat.
TQA likes this.
sony2000 is offline
post #6 of 7 Old 08-04-2013
Good suggestion but if he's anything like me and if he goes to the trouble of mixing and applying gelcoat, it could start a domino effect that will keep it out of the water until he has GREAT grandkids. Nothing wrong with a rattle can touch up on a project like this.
SJ34 is offline
post #7 of 7 Old 08-04-2013
I think that would work just fine. It will just be a lot heavier! But that should be a problem!!!!
mike dryver is offline
Rudder repair tayzay321 Helms 2 06-02-2010 09:01 AM
rudder repair christsake General Discussion (sailing related) 7 03-20-2009 04:41 PM
Rudder repair cutterorient Gear & Maintenance 8 02-23-2009 01:07 PM
Rudder repair dasnider Newport 3 06-16-2007 10:21 PM
Rudder Repair mas92102 Gear & Maintenance 2 12-17-2001 03:47 PM
